Mar 06, 2006, 07:33 AM
Rock On- Damon Atwood
dag214's Avatar
Build Log
196" wingspan Vintage Electric Plane
Hello all.
Go to post 923 to see my New EII (Emmaselle II)
This started over 6 years ago as a gas project. It is now electric, and will be flying at SEFF 2010.
Rock On!
This will be flying by may.
All of the airframe was constructed from materials purchased at Home Depot, Menards, and the local lumber yard.
The power will be a 3-W 150
13 servos
2 recievers
4 batteries
More pics at:
www.atwoodaviation.net
Mar 06, 2006, 10:35 AM
How much flying time does your pilot have?
Mar 06, 2006, 11:51 AM
dag214's Avatar
She has about 2 hours on a sim. But she would push the weight over 55 pounds. My target weight is 52 pounds with fuel.
She just loves to sit in Daddys planes.
Mar 06, 2006, 03:54 PM
Looks good. It will be great to see the rest of the build photos. It looks like your "pilot" will be needing a "trainer" before too long.
David DeLuca
Mar 07, 2006, 09:19 PM
dag214's Avatar
My 3d renderings that I produced my drawings from
These are a few renderings I drew with 3ds max. It helped me create the auto cad drawings that I cut the kits from.
Mar 07, 2006, 10:13 PM
Way cool. @52-ish pounds, what's the wing loading?
Also be sure to add on board video for the maiden!
G'luck!
Mar 08, 2006, 06:04 PM
dag214's Avatar
Power will be a 150cc 16.5Hp twin cylinder 2 stroke turning a 36 prop.
The Airfoil cord is 30 at 94 per panel= effective wing span is 188, true span is 196, M.A.C.# is 30, M.A.C. distance is 9, weight with fuel will be 864oz, wing loading will be 22.06oz/sq.ft, aspect ratio: 6.27.
She will fly like a trainer. I have plenty of power so I will be swinging a 36" prop.
Mar 08, 2006, 11:49 PM
Battery Junkie
wrenwright's Avatar
What are the details on your engine?
Mar 09, 2006, 07:02 AM
dag214's Avatar
It is a 3W 150iB2-F-CS engine. I normally have a 32" prop on it but with this plane (slow and Low) I am going to put a big prop and not run it a full power. I had it on a 53 pound 1/2 pitts and it would go vertical out of sight. 3W says it has something like 65+ pounds of thrust so it is WAY to much power for my Vintage plane. I am going to run it at low RPM so it sounds more like a full scale engine.
Mar 09, 2006, 11:45 PM
tailskid2's Avatar
Was your 'pilot' scratch-built
Jerry
Mar 10, 2006, 07:33 AM
dag214's Avatar
More build photos
Most of my planes have been yank and bank/3D types. This will be a slow putt putt around type plane, but she will be fun to see in the air. It will have onboard FM wireless cameras, 3 of them.
And yes, the pilot was scratch built, she took about a 45 minutes to get going, then 9 months to bulid
Mar 11, 2006, 08:07 PM
dag214's Avatar
3W 150 going to have a 36" prop
My son Hunter with my 3W 150 engine.
Weight is 9.2 pounds
Was on my Pitts that weighed in at around 52-53 pounds.
Start so easy you have to see it to believe it.
I got this from Gerhard at Aircraft International, Inc. He is really a great guy to deal with.
Best running engin I have ever owned.
Mar 17, 2006, 08:04 AM
Great project. Can you give us some details regarding materials used in construction e.g. wood used for stringers, formers and fuse sheeting. Also, you mentioned some design software you used. Can you provide some more details.
TIA,
Steve
Mar 17, 2006, 02:38 PM
dag214's Avatar
What she is built from.
Thanks Steve,
Ribs-3/16" plywood from an old shipping crate
Fuse stringers-2X4 and 2X6 cut down on my table saw. Most of the wood I have stripped to 1/8" strips then laminated and it made the wood really strong, guess thats why they did it in the old days.
Ribs cap strips-1/16 ply from shipping create.
Fuse sides-same as ribs.
The design software I lucked into with my job, its call 3ds max. It cost about $3,500.00, it came with my job. If you can find a copy of it you can easily create the aircraft in 3-D then export it to Autocad then plot your drawings to build form.
More of my designs at my website:
Mar 17, 2006, 03:51 PM
Thanks Dag, info greatly appreciated.
Regarding the design software, I have a Thule box on top of my car that's large enough for most of my planes but not long enough for some new sailplane wings, need something that will accommodate 95" of length. Was thinking that some sort of simple design software would allow me to layout a new Thule style design then create some formers to size that could be outputted to a printer. I would use these paper outlines to cut out plywood formers, fill in the spaces in between with foam blocks, shape the blocks to the contours of the formers to create a full size plug from which to make a fiberglass Thule to the length I need.
Maybe there's any easier approach to this...any ideas? I've considered a simple Sonotube with plugs at both ends but they just don't hold very much.
TIA,
Steve
For Sale Worlds Fastest Carbon Terminator ACTUAL 211mph Plane RTF *BUILT FOR DS* Z06kal Aircraft - Sailplanes (FS/W) 11 Aug 01, 2006 01:05 AM
Discussion REQ: Plans for beginner vintage plane! SoNgOkO Vintage & Old-Timer Designs 12 May 10, 2006 12:33 PM
Plane Storage Built for the Shop gsmith Slope 41 Dec 04, 2005 11:17 AM
Built-up airframe design for giant scale? surfimp The Builders Workshop 14 May 02, 2004 12:37 AM
