Mar 02, 2006, 12:57 PM
AZ Outback
Robert Burson's Avatar
Contest
X5j eXtreme March 11&12th Signup
X5J eXtreme 2006 and Event dates.
Welcome, back for the third year.
Please read all rules, rule 8 is new for 2006.
X5J eXtreme Rules:
1. Any electric sailplane can enter, to fly the following rounds, three 10-minute flights. One point per second of flight time, one point deducted for each second over the 10minute-flight time. Maximum points possible 600. Round to the closest second.
2. The BIG ONE, motor run time is unlimited but subtracted from the flight time. Example, 600 flight pts - 19 motor run pts = 581 total round pts.
Rules 1 and 2 are restated below:
The pilot will select three 10 minute flying windows, any motor run during this period of time will be subtracted at a rate of a point per second. Flight time will be one point per second (in 10 minutes 600pts minus motor run time points). Flight time exceeding the window will be one point for each second subtracted from flight time. (This rule now reads closer to F3J rules from FAI)
3. Landing points to be measured from the center of the landing circle, to the closest part of the plane. For each meter from the point subtract 3 points. See attached file for table.
4. Motor handicap: brushless 95%, brushed Cobalt 75%, Ferrite 45%, and Speed400 30%. Actual motor run rounded to the closest second. Then multiplied by the motor percentage. Round this calculated value to the closest 1/10th of a second.
5. Your flight is limited, a single dawn to dusk flight day of your choosing, during a 48 hour period.
6. Any type of battery cell is legal.
7. Temperature Factor to be added to total flight score. See the attachment for the temperature table.
New Rule
8. You may restart your, motor as many times, as needed, but on the second motor start, you may not add landing points. A second way of stating this rule. If you start your motor after launch run of the motor, you will not receive any landing points.
Timers still need two stopwatches, this was easier then I thought it would be. Work out a signal with the pilot, if he is going to restart the motor. (I.e. "restarting...on...off")
This is the simplest way of scoring I have been able to come up with.
Flight time - closest second
Motor run - closest second
Calculated motor run - closest 1/10th of a second
Landing points - see table Rule #3
On or by March 10th.
To compete: Please list your plane, gearbox, prop, cells and type, weight, and any other interesting facts, pictures are always welcome, to this thread.If someone else, not on the Web would like to fly with you please list him or her.
To all who enter,
The Best
Robert
The following are the dates for X5J eXtreme 2006:Feb. 18th and 19th
March 11th and 12th
April 15th and 16th
May 27th and 28th
June 3rd and 4th
July 1st, 2nd, 3rd, and 4th
August 19th and 20th
Sept. 16th and 17th
October 27th to the 29th Munice, Indiana, USA
First X5J World Competition 2006, events at the National field.
X5J Speed400, X5J eXtreme, and X5J Unlimited
Mar 02, 2006, 02:23 PM
Andy W's Avatar
Alright, let's try again.
AVA-E, Hacker B40 FAI 6.7:1 HM105, 7xGP2200, CAM 18x10.
[attachment]665437[/attachment]
edit - depending on conditions, and free time, I may end up taking my Sky Sergio over to the local school or church fields, and flying it instead..
Rocket 400, Cosmo 4.5:1,12x7.5 carbon prop
[attachment]759418[/attachment]
Mar 02, 2006, 03:42 PM
The Mr. Rogers of RC soaring
rdwoebke's Avatar
Back in with E-llegro Lite!
Last month was fun. BTW, you might want to sticky this thread....
Allegro Lite. Direct Drive Speed 400. 6x3 folder (modified). 2S1320 Thunder Power Lipo. Plane weighs about 22 ounces. I usually post the same picture of it, so now I am posting this one instead.
Ryan
Latest blog entry: Supergee wing mount pylons
Mar 02, 2006, 05:20 PM
jojoen's Avatar
No way I can get flying done I think. This weekend I am running Norway's biggest airshow on the ice with over 100 pilots. But who knows. Maybe I can get some airtime late in the day Sunday. If so it will have to be Graphite with B50 6S, 9cell GP2200, 18x11 again.
Mar 03, 2006, 04:57 AM
Tragic case
davidleitch's Avatar
Espada 12 x gp2200 17x13 B40 6L carbon case, or Organic 2.5 with 7 cell.
Mar 03, 2006, 09:04 AM
F3J, F3K and F5J eXtreme
markStockton's Avatar
I'll give it a try again. Still flying the Graupner Cumulus at 850grm with a ProMax Speed 400, 3.3:1 HiMax planetary gearbox, 14.5 x 7 blades.
Although I will try and get my hands on 8 X 1050 KAN's as 7 sucked really badly.
Mar 03, 2006, 02:16 PM
F3B enthousiast!
guillaume83's Avatar
Hi,
I'm in again.
Pike Superior/Cyclon Elite 10/Aeronaut 18x11/ TP 3s2p 4200 mAh Pro Lite - 2540 gr
or
Pike Brio/Cyclon Elite 10/Aeronaut 18x11/ TP 3s2p 4200 mAh Pro Lite - 2470 gr
Guillaume
Mar 03, 2006, 05:16 PM
Johan L's Avatar
Hello!
Of course I wanna take part agin!
X-400 BLK Sp400 6v gear 3:5, 11x6 prop, 2 x PQ-400XP-3S. Flying weight 390g.
Or my Softik 1.4. Modify with new boom and tail. APACHE APS 30-30T,
AP Air-30A speed controller, 10x7, PQ-1200XP-3s. Flying weight 450g.
/Johan
Mar 05, 2006, 09:07 AM
SEFF Contest Director
rcjunkie's Avatar
I'm off on weekends this month so I hope to make it out and fly. Koleos 1.8M with spoilers, rocket 400 w/4.5:1GB, 11 X 8 prop, 8 cell kan 650 or 3S 2100 TP, AUW 22 oz.
Ernie S.
Mar 06, 2006, 02:54 PM
tender
tender's Avatar
Im in with my old SENSOR-plus model (which won in March round 2005). But when I will be able finish one TANGO model for myself, I will be compete with this one. You can look my model today at noon >>>
Palo
Mar 07, 2006, 05:19 AM
ohmite's Avatar
I'm in again with either my Art Hobby High Aspect 3.1E or my Omega 1.8. Weather is supposed to be in the 50's by Saturday, hoohoo Spring is almost here!
-Eric
Mar 07, 2006, 09:53 PM
Closed Account
I will be trying to ignite some interest in the Kansas City area. Forecast is a little windy but they are usually off by quite a bit. Will be flying my Elliptron/Neu 1105/1.5Y/4.4:1 gearbox with a 11X7 folder using 7 GP2000 cells. This will be the first chance I get to try out the new composite V-tails (not shown yet in the picture). Hope to have more photo's at the end of the weekend.
Mar 08, 2006, 08:35 AM
Hello! I will try again.
Mini Allegro Lite 1,5 m 400 gear3,5 11x6 Prop 3 Lipo E-Power1250 or
Astro Challenger 600 motor and 7 cells. Weight 1275 Gram 7 5-4 Graupner Cam prop
/Roland
Mar 08, 2006, 03:24 PM
Pontificating Member
tone's Avatar
I sure hope to be in this time.
The last couple have had really unflyable weather down here.
Fly-Q (omega 1.8 wing on a 1.5 fuse looks like) Mega 400/12 - 9x4.5 - 3s 1320
or
Ascent (yep) same exact motor/prop/battery
Tony
Mar 09, 2006, 04:23 AM
spacey's Avatar
I'm going to sign up but same as last time I'm very unsure if I'll actually be able to find a safe place to land the glider. The sewer line has been dug at the field so my old grass landing patch is gone. I'll try to get some pictures of the mess
Anyways flying my usual Poly Sergio with a rocket 400 on a Cosmotech planetary swinging the no-name brand 12X8 folder. HS-55's all round and a JR R700 rx somehow squashed in. Oh and battery is the usual Kan 1050 8cell packs.
Best of luck to everyone! Hope the weather plays along this time!
Cheers
Rudolf
Discussion X5J eXtreme June 16th/17th Signup Robert Burson Electric Sailplanes 48 Jun 25, 2007 08:13 PM
Discussion X5J eXtreme March 10&11th Signup Robert Burson Electric Sailplanes 46 Mar 13, 2007 05:18 PM
Contest X5J eXtreme August 19th/20th Signup Robert Burson Electric Sailplanes 77 Aug 31, 2006 08:17 AM
Discussion X5J eXtreme NEW YEARS DAY 2006 SignUp Robert Burson Electric Sailplanes 77 Apr 06, 2006 09:47 AM
