lithium charger for 2 packs? - RC Groups
Feb 22, 2006, 04:26 PM
Does anyone make a lithium charger that will charge 2 packs at a time?
Feb 22, 2006, 04:30 PM
Southern Pride
everydayflyer's Avatar
his one will do four
http://www2.towerhobbies.com/cgi-bin...&I=LXKAU0&P=ML
This one does two
http://www2.towerhobbies.com/cgi-bin...&I=LXCTZ5&P=ML
as does this one
http://www.hobbico.com/cyclers/hcap0280.html
It is possible to charge packs of the same number of cells in parallel on any LiPoly charger if it has enough output. I have often charge 5 3S Packs of between 1200 and 1500 mAh on my Astro Flight 109 charger.
Charles
Feb 22, 2006, 04:59 PM
Oh ok I didnt know that. How do you wire a single charger to charge more than one battery? Like this? if you have 2 batteries. Make a charge cord with 2 say deans connectors and wire the connector + to+ and - to - ?
I like the duratrax ice charger it can put out 8amps of power.
What do you think about this charger?
Feb 22, 2006, 05:16 PM
Also if you have 2 1800mah batteries what amp setting should you use. 3600 or 1800?
Feb 22, 2006, 07:14 PM
Southern Pride
yes or use one of these.
http://www2.towerhobbies.com/cgi-bin...?&I=LXHHW6&P=7
Charge rate is based on total capcity so two 1800s would be charged at 3.6A for a 1C charge rate.
https://www.rcgroups.com/forums/show...03&postcount=8
Charles
AC/DC (Microprocessor Charger) Lithium Polymer Charger for 2 ~ 4 cells Pack AmondoTech Batteries and Chargers 10 Aug 04, 2005 06:10 AM
The Most Advanced Lithium Polymer Charger for 2 ~ 4 cells Packs AmondoTech Product Announcements 0 Jul 15, 2005 05:08 PM
Lithium Auto-Charger for 2-Cell Conversion Instructions Slow Riser Batteries and Chargers 5 Jul 03, 2003 02:05 PM
Lithium Ion Charger For 2 Cell Packs tnrwayne Aircraft - Electric - Airplanes (FS/W) 2 May 30, 2002 01:07 PM
What's a good, inexpensive slow charger for small packs? DaJudge Electric Plane Talk 5 Oct 28, 2001 10:57 AM
