Feb 11, 2006, 03:31 PM
BeechSkipperDude's Avatar
Help - Can't figure out what's wrong...
I have an e-flight 370 outrunner and it's compliant esc. after rigging all electronics in a new plane...all the motor does is beep once when i plug it in. for a few tries, the servos moved and everything seemed fine. then after trying to get the servo leads in the correct ports - now the servos only jitter once when i plug in the battery....
I tried 4 different rx's just to make sure but it did the same thing with all of them. is my esc blown? what do i do!?
thanks
Rick M.
Feb 11, 2006, 04:57 PM
Battery charged? Servo plugs in right and not backwards?
Feb 11, 2006, 06:33 PM
Dr Kiwi's Avatar
Is it a Futaba Tx - in which case throttle servo will need to be reversed.
Feb 12, 2006, 05:07 PM
no, no, no. (answering your questions)
I made sure the servo's were plugged in correctly, i was narrowing down where they went...i.e aileron servo in the elevator port.. i had two lithium batteries i was using for testing, both of which were charged. and no, there is nothing futaba about my setup...
The problem is. I've used this configuration in a sorta tensor for months... and now once i hook it all up to a new foamie, nothing works. any more viable suggestion? keep in mind i'm not a dumb***. i just would rather ask for advice before purchasing new, un-needed equipment. Thanks.
Feb 12, 2006, 05:45 PM
Dr Kiwi's Avatar
All I can suggest is trying one thing at a time - beg, borrow or steal, then try, a different motor, different Tx, different Rx, different ESC until you find a combo which works - then you'll have the answer.
Feb 12, 2006, 07:58 PM
Rick, It sounds like your electronics do not like foam. That is why all of my planes are balsa, Ply and MonoKote.
I am sure you have tried this, but wire a four cell ni-cad or dry cell battery pack up and plug it in to your reciever with out the ESC and see if the reciever and servos work.
Discussion Help me figure out what went wrong PROACE Racing Boats - Internal Combustion 3 May 01, 2006 10:43 PM
Question Can't figure out how to setup an EF radio for any sim, help.. RisingSunn Simulators 0 Feb 26, 2006 06:33 PM
Discussion HELP!! - Can't figure out how to get new scenes from rc-sim.com working in Reflex?? kenmalecki Simulators 3 Feb 22, 2006 10:27 PM
Help! Can't figure out what to do. rcnutt Electric Plane Talk 9 Mar 17, 2003 06:23 PM
My Endo lost it punch and I can't figure out what to do Balin Sport Planes 25 Jun 16, 2002 10:07 PM
