Jan 21, 2006, 02:06 PM
rchawks's Avatar
Corona tail rotor runout
After aligning the boom and the main rotor gear it's very apparent the the tr gear is running out by at least .01 maybe more. This is a brand new gear and I'm wondering if there was a bad run. Has anyone else come across this problem?
Jan 21, 2006, 02:25 PM
When you say "running out" do you mean running off center?
Is this the crown gear on the main shaft or the gear on the drive wire?
Jan 21, 2006, 04:42 PM
rchawks's Avatar
It looks to me now that the plastic gear that's pressed on the alum. hub is the problem. I have two of these pinion gears and both are defective. The tail rotor pinion gear on the crown gear side of the boom is not turning on center. So I guess the only choice I have is to split the diff. and to adjust by sound as has been suggested. There is nothing wrong with the drive wire.
Corona Tail Rotor Server Burned Out vkmaynard Electric Heli Talk 18 Jan 31, 2003 03:28 PM
Corona tail rotor washer. Help... nrthwing Electric Heli Talk 6 Dec 23, 2002 11:43 PM
corona tail rotor J328 Electric Heli Talk 2 Dec 10, 2002 03:23 PM
Corona tail rotor gear mesh GKurt Electric Heli Talk 4 Nov 22, 2002 05:00 PM
Corona tail rotor stutter Eradicator Electric Heli Talk 3 Jul 21, 2002 11:08 PM
