Jan 13, 2006, 04:47 PM
mnfiero's Avatar
Futaba 7CHP programming question, Dual Throttle Mixing
Here is my project:
https://www.rcgroups.com/forums/showthread.php?t=460061
Tx:
Futaba 7C
RX:
GWS 6ch
Here is my issueÖ
I want to have the front fans to be controlled with the left stick. Up and down being the throttle amount and left and right would be the roll control (pulls and adds throttle from one side to the other). I think post #11 of this thread: https://www.rcgroups.com/forums/show...t=throttle+mix could help some, but Iím not sure if Iím on the right track. Iím using channel 1 and 2 in a v-tail mix for the fan articulation and channel 6 for the rear fan. I may use one of the other open channels for my gyro mode switch. Being a web programmer, I can visualize the mix in my head, but I need some help applying it to the radio.
Any help would be appreciated.
Lyle
Jan 16, 2006, 11:49 AM
mnfiero's Avatar
Well Lyle,
It sounds like what you are trying to do is a v-tail mix on the throttle and rudder channels. I think you may want to try a onboard v-tail mixer. At about five grams and around $15, I think it would be the best solution. Especially since you are all aready using your pre-programmed v-tail mix for your other stick and there is no good way to get that mix on to your throttle and rudder channels with the 7C.
I hope this helps,
Lyle
Question Futaba 7CHP programming question. mdelzer Radios 16 Jan 13, 2006 02:10 PM
Futaba 9C programming question Parahawk Radios 0 May 15, 2004 01:32 PM
Question futaba 9C programming question garthebar Sailplane Talk 0 Apr 27, 2004 10:42 PM
Futaba 8u Programming Question Alan W Electric Plane Talk 5 Jul 28, 2001 12:21 AM
