Dec 29, 2005, 04:04 AM
Capgun_Slim's Avatar
Show Us Your Easy Glider!
I searched to make sure nobody had started one already, so here Goes! I hope this turns into a biggie thread! Please list any mods done, as well as setup. I'll start first,
Easy Glider Electric
Phasor 30/3
Jeti Advanced Plus 40 ESC
GWS Naro 6 Channel RX (soon to be Berg, or electron)
2 Hitec HS-81MG servos
2 Micro9 Servos in the wings
TP 3s 3200mah Lipo
11x6 Graupner Folder
Standard 96 cent black gloss Walmart enamel for canopy
Testors metal flake green on fuse and wingtips
2 pieces each side under wingtips, carbon fibre tape glued on with GWS cement
1 Carbon Fibre rod (about the size of an arrow shaft) cut into 3 pieces and imbedded in, the length of the bottom of fuse
Clear packing tape laid on both wings leading edge.
2 layers of strapping tape laid on bottom of fuse for landing skid
Dec 29, 2005, 06:55 AM
Kyri's Avatar
Easyglider
Mega 16/15/3, Maxon 4.4:1 g/b, Aeronaut CAM 14x12, (HM lite spinner 38mm)
3S 2220 LIPO
40 Amp tornado esc, pulls around 35A static
Servos Jr241 elevator, 2 x HS55 in the wing, no rudder
The glass tube was replaced with a stiffer and lighter carbon one.
I got one of the first ones and its still one of my most flown planes.
Regards
Kyri
Dec 30, 2005, 09:09 AM
Git-R-Done
Hermitt's Avatar
Hi CS,
Thanks for the invite to join this thread.
Guess I'll post a few pics of our EZG which we (My Son and I) built a couple months ago.
Here's what powers it....
Jeti Phasor 30/3 with 11x6 Graupner folder
Jeti Advance Plus 40 amp esc
Hecell 3s 4000mah LiPo
Controls: Ailerons & Elevator.
Servos: (3) gws Naro's
RTF Weight: 44oz.
It flies like a dream.
VIDEO
Dec 31, 2005, 01:48 AM
Here's mine.
Speed 480 motor
Stock gearbox
Graupner CAM 10X8 folding prop
E-Flight 20 amp ESC
8 cell, 1600mah, NiMh battery
Hitec HS-55's for the ailerons
Hitec HS -81MG's for the tailfeathers
Strapping tape applied to the lower fuse, and clear packing tape applied to the LE of the wings. (Not shown on photos)
I dug out the steel ball in the tail yesterday because it was very tail heavy inspite of the larger motor. (For those of you just starting your assembly, leave out the steel ball! What a pain to remove!)
Jan 10, 2006, 12:40 PM
Git-R-Done
Hermitt's Avatar
Hi C_S,
Have you maidened your EasyGlider yet?
This thread appears to have stalled...??
Hermitt
Jan 10, 2006, 04:09 PM
george l's Avatar
Thanks for starting this thread. I've been wanting to get one of these. Now, looking at your picks, it looks like I will have to take the next step and order one. Any advise as to where to get the best deal?
Jan 10, 2006, 07:25 PM
Git-R-Done
Hermitt's Avatar
You might want to google it and see who sells it cheaper.
I got mine here...http://www.hobby-lobby.com/easyglider.htm
Tower Hobbies also sells it. http://www2.towerhobbies.com/cgi-bin...?&I=LXKHS8&P=V
Jan 11, 2006, 07:47 PM
Here's my EasyG-elec:
- Tamiya Florescent orange paint & Tamiya metallic blue for canopy colors
- Uses a 3:1 MPI Gearbox, Hyperion brushless motor, hyperion 30 amp esc, 10x8 Graupner cam folder
- Set up for both spoileron/flaperon using an airtronic rd6000 super transmitter and hitec electron 6 channel receiver
Jan 11, 2006, 08:05 PM
Git-R-Done
Hermitt's Avatar
Magnus, I like your paint scheme.
Very nice looking plane.
Hermitt
Jan 11, 2006, 08:33 PM
windsox's Avatar
Which hyperion are you running?
Jan 11, 2006, 08:59 PM
windsox - I'm using a Hyperion Y22L 2840kv brushless. It has the same dimensions of a brushed speed 400 and the same output shaft. Got it from Air Craft World - Japan
hermitt - thanks for the compliment. The colors extend to the underside of the painted sections and they really help in orientation. Unfortunately I had a case of "dumb thumbs" last Sunday and planted the nose into the ground. Looks like I'll need to replace my gearbox
Jan 11, 2006, 10:49 PM
Git-R-Done
Hermitt's Avatar
Originally Posted by Magnus
Unfortunately I had a case of "dumb thumbs" last Sunday and planted the nose into the ground. Looks like I'll need to replace my gearbox.
Oh No, sorry to hear about that.
Happy flying,
Hermitt
Jan 13, 2006, 10:12 PM
Well the damage didn't turn out to be that bad. Spinner and backplate was cracked but the props are ok. Receiver crystal pins bent (easily bent back to normal). Motor and ESC work fine. Gearbox is surprisingly intact except for one of the bearings on the shaft. Fuse was crinkled in some parts but nothing like a good boil should straighten it out. Looks like the elapor absorbed the impact well.
Jan 15, 2006, 04:46 PM
Does it come in Flouro??
Numb Thumbs's Avatar
Hi guys
Here is my EZG.
You can't have too much Flouro!
Maxx Motors 400F outrunner
Stock gearbox
Graupner CAM 11x6 folder
MP JET spinner
PolyQuest 2200Slim 3s
videos at:
http://www.numbthumbsandloopy.net
Cheers
Numb Thumbs
Honorary President of the International Order of Flouro Fellas - IOFF
Jan 20, 2006, 02:50 AM
Carl
Michnet76's Avatar
Originally Posted by Numb Thumbs
Hi guys
Here is my EZG.
Hi Numb Thumbs... you wouldn't happen to go by the real name of David? I recognise your proprietory flouro orange scheme on a Twinstar being posed with a grey haired, bearded gentleman in the last RCMNews 'flying electrics' section!!
I first noticed the EGE from the review by David Hipperson on the following pages of the above mentioned magazine and as I've been thinking about getting another glider I went and ordered one.
Couple questions I'm hoping to get answered if anyones' willing... I've spend the last couple days scouring these threads and can't quite seem to get a straight answer...
1. Are you guys taking off the small mould dimples?
There seems to be mixed opinions about this... the reviewer in RCMNews, David Hipperson, recommends it and to use fine sandpaper to do the job. Others on this site have recommend to use a blade! D'oh! no thanks! I messed around sanding some off underside the horizontal stab and noticed that it also takes off the shiny finish of the elapor... is that ok or should I be trying to keep that sealed look finish? I would prefer to take em off as the dimples kinda give it that cheap foamy toy look.
2. Are you guys preping the elapor foam prior to painting? I notice MX recommend their MULTI-Primer. I can't seem to get ahold of that stuff around here so is there a simple alternative like sanding or something else?
3. This ones' for aussie peoples, what's a good brand spray can to use? I'm off to adelaide tomorrow so I should be able to get access to most brands.
4. 'Cause elapor isn't a real stiff surface, does the paint crack and flake off the elapor? I have a parkzone stryker (EPP) which I painted with waterbased artists paints through an airbrush and after a couple months of use (and a hard landings!) the paints' all cracked and flaking off and I have to continualy brush more on to keep it nice.
Any help and suggestions are more than appreciated!!
Discussion Show us your scratchbuild foam (Motor) Glider !!! chara Foamies (Scratchbuilt) 266 Nov 25, 2019 12:04 PM
Show us your airplanes! sneu Electric Plane Talk 21 Sep 20, 2009 01:03 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 08:23 PM
Show us your wildest Zagi Dave Seay Foamies (Kits) 9 Jan 23, 2002 02:22 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 11:50 AM
