Nov 28, 2005, 06:13 PM
Big gov never Works
St. Martin's Avatar
Yippee!
Warbirdkits IAR-80 SP-400
I've been busy finishing the RT-Models MiG-15, over in the EDF forum. But, I'm back with another one of Tom Jacoby's little gems.
W.S....34"
LOA...29"
WA...146sq"
AUW...17-19 oz
Scale ratio..1/12 (1"=1')
The parts are lazer cut, as all of Tom's designs, and was of high quality as also was the wood supplied. The cowling is a vacuum formed plastic of sturdy thickness and is two piece(foward/rear). The canopy is beautifly done. Also included is a few molded plastic scoops.
Plans are clear and easily understood for anyone with a few kits under his belt. Included is a worded construction manual. Simply worded and easily understood.
The construction is very light. Care must be taken to avoid breaking the bukheads. But, once the keels are in place and planking has begun, it has high strength/little wt. I strengthened the rear bulkheads by absorbing a small amount of thin CA into the side end grain of the bulkheads.
This plane will be covered in silkspan and lacquer for lightness. I will be offering this plane for sale upon completion.
Steve
Nov 28, 2005, 08:35 PM
Manzano Laser Works
TomJacoby's Avatar
Steve,
It's really just a single scoop, in two pieces, so you can make it a break-away scoop if you want.
All the plastic work, including the plugs, was done by Joel Dirnberger aka MetroGTI at Ezone. Joel does fantastic work!
You should also have found a vac-formed spinner in the kit... Let me know if I need to send one to you.
Tom
Nov 28, 2005, 08:46 PM
EB-66C Team Member
J Morgan's Avatar
...and the building machine ground on and on and on........
Fuzz, you remind me of the Energizer Bunny.
J
Latest blog entry: Ziroli A-1H at 100"ws
Nov 28, 2005, 09:36 PM
Manzano Laser Works
TomJacoby's Avatar
Iar-80
The IAR-80 was a nimble fighter developed from the Polish PZL-24 series aircraft. But it was underpowered and obsolete by the advent of WWII.
Cannon-armed variants of the IAR brought down quite a few USAAF B-24 Liberators during raids on the Romanian oil fields, but P-51 Mustang pilots found them easy meat.
Nevertheless, under the right circumstances, Romanian pilots and their IAR-80 fighters were deadly adversaries. Their finest hour came on June 10th, 1944, when 23 Romanian Air Force pilots of the 6th Fighter Group, flying IAR-80s, bounced more than 40 P-38 Lightnings in a shallow valley. In the four minute fight, the Romanians shot down 14 of the P-38s for a loss of five IARs.
The IAR-80, though little known, is one of those classic fighter designs, and one that I've wanted to model for years. This model is based on a combination of various three-views and photos, and is as close to scale as I could make it. All the drawings I've found generally agree on the profile, but vary widely on the fuselage plan view forward of the cockpit. Ultimately I shaped it to conform closely to the 1:48 plastic model produced by LTD.
I hope you enjoy building and flying it as much as I enjoyed designing it!
Tom
Nov 28, 2005, 11:04 PM
D-Rock's Avatar
could you fly this model on a geared himax 2025-4200? It looks like a nice kit!
D-Rock
Nov 29, 2005, 05:08 AM
Big gov never Works
St. Martin's Avatar
Tom, I found no spinner in the box. I never removed, except the plans and manual, till yesterday. OK on the scoops, I see it now.
D-Rock, using the geared Hi-Max would require a very low ratio to get the pitch speed. Using a large prop on these little planes causes torque issues. DD motors that can turn a prop in the 7-9" range is a better choice. If you can turn a 9" prop and attain a pitch speed of atleast 45mph, then you will be safe.
Steve
Nov 29, 2005, 05:09 AM
Big gov never Works
St. Martin's Avatar
J
I have to, CB.. No job yet.. I have to build and sell to pay the bills..
Fuzz
Nov 29, 2005, 09:13 AM
Manzano Laser Works
TomJacoby's Avatar
Steve
I will ship a spinner this week - the IAR-80 wouldn't look right without it!
Did I include a set of magnets for the cowl in that kit? If not, I'll ship them, too.
-t
Nov 29, 2005, 09:25 AM
Manzano Laser Works
TomJacoby's Avatar
Follow the Build
Folks, you can download the construction manual for this kit from www.warbirdkits.com. Then try to keep up with Steve as he does another SPEED BUILD
Also available as free downloads are the kit decals and a paint and markings guide. The download links are near the bottom of the IAR-80 page. Enjoy!
Tom
Nov 29, 2005, 10:14 AM
Big gov never Works
St. Martin's Avatar
Tom, cancel that.. I dumped the foam peanuts in the trash and found the spinner camoflaged in Kinko wrap..
Steve
Nov 29, 2005, 10:35 AM
Manzano Laser Works
TomJacoby's Avatar
Steve
Great! Let me know if you need the magnets.
-t
Nov 29, 2005, 08:16 PM
EB-66C Team Member
J Morgan's Avatar
Wow! This is a speed build! Hope you're getting enough sleep Fuzz. Fuse looks great.
J
Nov 30, 2005, 01:40 PM
Manzano Laser Works
TomJacoby's Avatar
That crutch design really helps speed things along and keep the fuselage nice and straight. I don't know who innovated the use of this type of crutch, but I sure thank him!
Tom
Yippee! warbirdkits.com Yakovlev Yak-9D SP-400 Beta build St. Martin Scale Kit/Scratch Built 94 Sep 10, 2005 07:38 AM
Reno 2nd sp 400 pylon race kormak High Performance 2 Aug 08, 2001 02:15 AM
NiMH 1000's for Sp 400 ? Kevin Murray Electric Plane Talk 13 Aug 06, 2001 09:26 AM
sp 400 weights??? buckeyes1997 Power Systems 2 Jul 09, 2001 12:09 AM
6V or 7.2V sp 400??? VaVol Power Systems 2 Jun 28, 2001 09:12 AM
