| Thread Tools |
| This thread is privately moderated by lawrence4, who may elect to delete unwanted replies. |
Build Log
ZWAZO - JIVARO-MODELS from ROCKET LAUNCH to motor build log and maiden flight
ZWAZO
C.G 225mm Weight 288g Wingspan 798mm (114%) Length 660mm Height 90mm Motor EMAX MT 1804 2480KV ESC Favourite SKY-III12A Propeller 3045*3 ( power less than plane weight ) Servo EMAX ES08AII x 2 Receiver Frisky D4R-II 4ch Battery 3S GAONENG HV4.35V 550mAh Plan: https://jivaro-models.org/zwazo/page...html#gsc.tab=0 12V Running LED lights Material: 1. 10K resistor*5 2. 10K variable resistor*1 (variable speed) 3. 10uf 50V capacitor*1 4. 12V LED red*6、green*6 ;orange*4 5. Single LED red*6, green*6 5. NE555 IC x 1 6. CD4017 IC x 1 7. 12V battery Step: 1. NE555 pin 2 to pin 6 2. NE555 pin 4 to pin 8 3. Capacitor - to pin 1 ; + to pin 2 (NE555) 4. 10K resistor pin 7 to pin 8 (NE555) 5. 10K variable resistor pin 6 to pin 7 (NE555) 6. CD4017 pin 8 to pin 13 7. CD4017 pin 15 to pin 13 8. CD4017 pin 8 to NE555 pin 1 9. CD4017 pin 14 to NE555 pin 3 10. CD4017 pin 16 to NE555 pin 8 11. 12V LED - to CD4017 pin 8 12. 12V LED① + to CD4017 pin 3 13. 12V LED② + to CD4017 pin 2 14. 12V LED③ + to CD4017 pin 4 15. 12V LED④ + to CD4017 pin 7 16. 12V LED⑤ + to CD4017 pin 10 17. 12V LED⑥ + to CD4017 pin 1 18. 12V LED⑦ + to CD4017 pin 5 19. 12V LED⑧ + to CD4017 pin 6 20. 12V LED⑨ + to CD4017 pin 9 21. 12V LED⑩ + to CD4017 pin 11 22. 12V battery - to CD4017 pin 15 23. 12V battery + to CD4017 pin 16 Wing top LED left side of wing top and wing tip LED red*6, 12V, no resistor. Right side of wing top and wing tip LED green*4, 12V, no resistor. wing top LED green x 2 and white x 2, 12V, no resistor. Note: Green LED 3~3.2V White LED 3~3.2V Red LED 1.9~2.1V PS. Sorry about the photos not in order. ImagesView all Images in thread
Reason: Add pictures for JUMPER T16 PRO image.
The propeller and transparent film all buy from local model shop. The propeller is not 3D printed. The transparent film have no product tag on it. Maybe you can find more transparent film with different colors made from Japan. |
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| Video | Rapture 40 From Build Log Maiden Flight | Tweener | Fuel Plane Talk | 2 | Apr 02, 2007 09:00 AM |
