Nov 25, 2005, 12:14 PM
thomanie's Avatar
Build Log
Building my s400 FW190
Hi,
My Ryan Corsair has been in need of an adversary for a while. So it was time to build a FW190! I'm doing one of the stubbier earlier models, not the long fused "Dora" version.
First picture shows the nice looking Flugewerke FW190.
The plans were drawn to give a 30" span. Foamcore wings with torquerods embedded and 1/32 sheeting for ease of construction. The fuselage is built around a crutch to ensure a straight and true fuselage. Thin balsa and ply formers and 1/16" sheeting. 1/8" balsa tailfeathers.
The 190 will be powered by a brushed Multiplex 480, APC 6x4E, and 8 cell GP1100. Might even go BL with a nobrand 400T or Mega 16/15/6 on APC 7x5E or 8x4E. Aileron, elevator and throttle control.
Hopefully it will work out fine - so lets get to it...
I've been building a little the last few days, and will post the rest of my progress as I go.
Thomas
Nov 25, 2005, 12:25 PM
thomanie's Avatar
Foam cores
Cutting the foam cores isn't that hard once you have don it a couple of times. Mine still turn out (really) bad once in a while. It's a good thing there is balsa sheeting to cover up my goof ups
First pic shows the blanks being cut to shape. I use two straight angles clamped to the tabletop and guides, and position the blanks accordingly - then make the cut.
Remember to set 2 degress (1/8") washout at the tip rib.
Then thin plywood templates are cut, drilled for a few long pins and pinned to the blanks. The wing is then cut using a large enough bow. Theres ample infomation on rcgroups on how to build you own - just do a search.
T
Nov 25, 2005, 12:36 PM
thomanie's Avatar
Wingskins
Wingskins are prepared from 1/32" sheet. The sheeting is "buttjoined" or "tape-hinged" whichever you choose to call it, then glued and weighted down while curing.
I used DB sorghum to glue to skins to the cores. After applying to the skins and the core, and letting it dry for 45 minutes, everything is left to set while weighted down in the foam beds from the cuts.
T.
Nov 25, 2005, 12:43 PM
thomanie's Avatar
Adding the LE stock
The 1/4" thick balsa LE stock was glued on while taping it to the wing to hold it in place.
T
Nov 25, 2005, 12:54 PM
thomanie's Avatar
Aileron torquerods
The ailerons were cut free and lined with 1/8" balsa both at the TE of the wing and LE of the aileron. In the picture you can also see the 1/2" tip blocks
After bending the torquerods to shape, the wings were grooved, the torquerods glued into place, and everything covered up with a piece of 1/8" thick balsa stick.
T
Nov 25, 2005, 12:57 PM
thomanie's Avatar
Adding tip blocks
Time to add the tip blocks and the ailerons.
Tip blocks were taped in place while the glue sets. The ailerons were drilled and grooved to suit the torquerods. After cutting the aileron part of the tip block free, they are glued to the ailerons. After a lot of planing and sanding, the two wing panels were finally done.
Well, almost... The ailerons still needs to be hinged, and the halves must be joined.
T
Nov 25, 2005, 02:06 PM
Gravity sucks.
mrittinger's Avatar
Wow, you build FAST!
Looks nice....maybe the 480 will be overkill?
I ran a long can 400 on 3 lipo with a 5/5 and it went very well. Cowl might be big for that on this bird, likely to go 6 or 7" diameter if you can.
SHould be nice bird when you get done, thats for sure
Mark
Nov 25, 2005, 02:24 PM
thomanie's Avatar
Fuselage crutch and formers
The fuselage crutch is made from 1/8" scrap plywood. Not exactly aircraft grade material this one as you can see. But it doesn't matter as it will be pulled out once the basic fuse has been built.
Printouts for the formers are also shown in the second pic.
T.
Nov 25, 2005, 02:35 PM
thomanie's Avatar
Originally Posted by mrittinger
Wow, you build FAST! ...
Not sure about fast, but a lot. Just ask the missus
A 5x5 will be too small I think. The 6x4 on my T-31 is almost dwarfed by the cowl, but it works fine. The 190 is almost as big - about the same size as my Ryan Corsair cowl behind a 7x5. I've been having really good results with the mpx 480, APC 6x4E and the 8 GP1100s. Cheap and effective combo - and I have a spare one laying around
Thomas
Nov 25, 2005, 02:42 PM
thomanie's Avatar
Fuselage formers
Started cutting the fuselage formers from the rear.
After a while they were mostly done, and trialfitted to the crutch. There are of course a couple of goofs here as well. The worst being that the inner diameter of the front former is too large. Added the slots for the crutch to the wrong side of the circle. *doh!*
Fixed the drawing, and added a couple of scraps to the rear of the former. Also had to redraw the LE former as I got the shape totally wrong on the first go. Verified by a few online pictures...
T
Nov 25, 2005, 02:57 PM
thomanie's Avatar
Mock up...
Last pic for now - I just have to see what a build is going to look like every now and then.
You can't really tell it's a FW190 yet - but soon. Very soon...
T
Nov 25, 2005, 03:45 PM
At the 30" size, a small 1.6oz Eflite outrunner or something of that nature would be fine, and at the light weight will fly much easier. Here's a 27.5" Guillows with the 1.6oz bl outrunner motor. 12oz with 3s-900 lipo.
Nov 25, 2005, 03:47 PM
Gravity sucks.
mrittinger's Avatar
Where'd you get a 190 s400 plan? Looks nice...
Nov 25, 2005, 04:05 PM
UAS Pilot - FAA# *******HRK
CryHavoc's Avatar
Thomas
What kind of amp draw are you getting with this combo?
Also, do you think you will sell plans for this plane. I would love to have a set.
Nov 25, 2005, 04:07 PM
thomanie's Avatar
The plans are my own - based on 3-views from a russian site
Thomas
Discussion Building my s400 Curtiss Hawk 75 / P-36 thomanie Scale Kit/Scratch Built 114 Jul 09, 2010 05:02 PM
Discussion Building my s400 Fairchild T-31 thomanie Scale Kit/Scratch Built 97 Jun 07, 2006 04:18 PM
Any tips on building my new Vortex CC? WilliamSettle High Performance 20 Aug 15, 2005 01:55 PM
Building my S400 Me 262 (designed by M. Rittinger) jfrabat Pusher Prop Jet Models 134 Mar 30, 2005 11:37 PM
Building my own NIMH packs? JayParke Power Systems 5 Oct 17, 2001 09:18 PM
