Those links are great fellas, they both have the motors kv. However neither one of them gives the internal resistance or the no-load amp draw.
I'm always willing to try and learn something here. How do I get the numbers I've asked about with the info that is on those pages? I did send an email to Warbirds RC asking for this info. Hopefully this is something that they can send back soon. The money for this is in my pocket right now, tomorrow it might be a different situation. |
My "Sexy Betsy"
I just come across this thread and spend some time to watch all these wonderful models *twothumbsup. After reviewing 51 pages I thought it would be a good idea to post also some images of my all-in-wood Jerry Bates B-26 Marauder in 1/8 scale
Dimensioning the drive for such a big model isn't a problem only the financing was pretty difficult. Unfortunately I overestimated my financial possibilities and so the model have to remain as a hangar queen till I have the money for the 2 10S2P Tanic LiPo Packs This model is completely equipped with all r/c components and ready to liftoff. I only have to load the LiPo packs in the nacelles to become ready for TakeOff. Some Details : 108" span. estimated lift off weight : ~37 lb 2 Actro 40-5 brushless outrunner 2 10S2P Tanic LiPo packs (each 5000mAh) 2 APC 16x10 props ~7300 rpm by 40 A current ! 2 Hacker 77P flight opto ESC's pneumatic robart retracts (designed for this machine) all hitec servoc (most HS645) 4 servos and electronic v-switch for the flaps Futaba PCM DS receiver If anyone is interested in more details I can recommend my building thread at RCScalebuilder.com (you have to register first at RCSB) In a german modelbuilder forum are also 2 threads : Part I Part II During the time of building this model and writing all these posts there where unfortunately no time left to update my WebSite but now where my Betsy is finished I have sure some more time . . . . I hope Enjoy |
LABstar,
That is one beautiful effort.........there aren't very many guys that would do a Marauder! Please be sure to follow up with a report when you get it flown. What is it's all up weight as it sits without batteries? -Mike |
Reason: typo.......
My Pair of Warbirds
My warbirds. The P-40 is a HET purchased through Tdl Models and is waiting to maiden. The Mustang is a Laishing with upgraded electronics. The motor is underpowered and needs to be replaced. Four flight attempts= Two crashes and broken fuselage, Two "Just can't seem to pull this thing with the stock motor..."
Reason: spellcheck
JUST FOR A BIT OF DIFFERENCE. This plane is a Slope Soarer.
"Kit Bashed" from the Ripmax Alienator kit to look like the Russian S37 "Berkut", forward swept wing experimental fighter. It's all Styrofoam with no covering, just painted. It has wood wing spars and is re-inforced in critical areas with F/Glas packaging tape. The nose is EPP foam, "Barrel Wrapped" with packaging tape and covered in white Oracover, for "Survivability". It has a big RX battery to get the balance and as a result can fly practically indefinitely if the wind holds up. Longest flight time so far 1 1/2 hrs. After more than a year of flying it is still virtually undamaged. It's no Hangar Queen. Cheers. Paddy. P.S.---LABstar. That B-26 is just mind blowing. The Marauder is one of my fave WW2 planes. |
I must have one. Must. Where, when? I've got the $350 ready.
Glen |
Saw many Spitfires the page before so I will jump in and post too.
This is my 3rd RC Spitfire and took 3 months to build. The last one crashed due to some malfunction?! It spans about 40 inch ws. Powered by a 3810 brushless outrunner and 8 kan 1000s. Has done close to 100 flights. No vices. Weighs about 25 oz loaded. Flies well. Completely scratched build based upon a Marutaka plan. I however modified the plans quite dramatically, espeally the tail feathers, main gear location and fuselage formers. Self moulded canopy. Paint is just plastic modeller Gunze Sankyo Wood 43 and green is a local spray can. Covered with light films. |
Thanks for your comments buddies I'm pleased that you like my work and when the model has flown I will sure update this thread
The total weight without batteries is ~30.86 lb (14 kg). I sure could have saved some more weight if I had been more attentive right from the beginning. There are always options to save some weight. But this is a big bird and shouldn't have any problems with the wingloading. Power/weight ratio is also well so when I got my nerves under control my Betsy should fly But whatever will happen . . . till now I had some years of very satisfying work This is a great thread . . . please keep it alive Cheers!, LarS 8^) |
Thread Tools | |
Similar Threads | |||||
Yippee! | SHOW OFF YOUR SCHEMES!! Warbirds! | punkindrublik | Painting and Finishing Tips | 425 | Mar 17, 2024 06:25 PM |
Gallery | show your multi-engine warbirds | Citabria86614 | Electric Warbirds | 803 | Jan 28, 2024 06:26 PM |
Discussion | Show Your Warbirds! | Draven | Foamies (Scratchbuilt) | 113 | Jul 30, 2022 04:29 PM |
Show your support! (for soaring) | hardlock | Electric Sailplanes | 1 | Jan 08, 2002 12:25 AM | |
Lazy Bee: show your pics? | Mike Wood | Sport Planes | 10 | Oct 31, 2001 06:08 AM |
