Sep 02, 2017, 10:37 AM
If the servo of the bottom wing I think when landing will be broken
Mar 03, 2018, 02:36 PM
My second superbandit, this built friend of mine for me, is 100% scale version covered by self-adhesive foil . Power setup Turnigy 2826-6 (2200kv) with balanced APC 6x4 E prop, ESC Hobbyking 40A/5A BEC , servos 2 x Corona 929MG on ailerons and NONAME 12g MG servo on elevator, battery Turnigy HeavyDuty series 3s 2200 mAh 60C (200g with glued welcro). RTF Weight 680g. I need do some stickers and will be ready for maiden flight.
Dec 10, 2018, 01:12 PM
hello friends !! .... I'm from the south of Spain and I decided to build my first superband with 64mm edf FMS at 109% and change the material ... I will not use foam board and I prefer 3mm corex ... something heavier but a good durable material ...... some construction guide for this nice bird? ... I hope the whysky friend appears around here...
I do not know if corex 3mm is not enough for the wing, even if you insert a carbon rod ... maybe something thicker material or double stick
I hope any help during its construction ... thanks
Sep 19, 2019, 12:27 AM
Valius's Avatar
Mine has the same power plan edf 64mm, plane made from 6mm floor foam plates, but the wings are made from 3mm plates all model is laminated. Now it's
not completely assembled, hope will fly well.
Sep 19, 2019, 01:59 AM
CrashingDutchman's Avatar
That look great!
Sep 27, 2019, 12:09 PM
Valius's Avatar
Thanks.
Finally had mine maiden flight!����
Seems so fast, but I guess will make it. It is my first EDF, so impresseions are too many ��
Apr 17, 2021, 12:52 AM
My Super Bandit 820mm wing span. Lights controlled by Arduino board, pusher jet.
Ultra BANDIT, RC model letadla (1 min 33 sec)
Oct 13, 2021, 09:09 AM
prop wash
biggy boy's Avatar
Bandit size for an 70MM EDF
Your Bandit looks nice and appears to fly nice too!
I'm looking at building one and using a 12 blade 70mm EDF.
Would I need to increase the size of the plane to suit the 70 MM fan? Or would the 32 inch wing span be OK?
Originally Posted by yeah74
My Super Bandit 820mm wing span. Lights controlled by Arduino board, pusher jet.]
Glen
Build Log Sukhoi Su-37 Super Flanker Park Jet jetset44 Pusher Prop Jet Models 3845 Sep 13, 2023 04:26 PM
F-100 Super Sabre 33 inch WS Depron Park Jet fuelsguy Pusher Prop Jet Models 124 Dec 17, 2009 09:39 PM
Video F4 Phantom w/ Little Screamers Super Park Jet Bajora Electric Plane Talk 84 May 06, 2009 01:08 PM
New Product super park jet ouluckydogu Electric Power Systems 2 Mar 23, 2007 02:33 PM
Video Little Screamers Super Park Jet on 4S (6mmflyrc F4 Phantom II) Bajora Electric Plane Talk 10 Mar 04, 2007 03:30 PM
