Oct 24, 2005, 08:32 PM
prop wash
biggy boy's Avatar
3d foamy Citabria just flew it
I just flew my 1/2 inch blue SM foamy. Plans from 3D foamys web site.
The thing actualy flys at 20 oz. I guess 32oz. of thrust helped
Anyway its a cheap build at $ 5.00 for a 24" by 8 ' sheet.
specs:
Walkera 180l 3200 Kv motor in a gws 6.6:1 box
12x6 SF GWS prop and 3s 2100 TP lipo
25amp CC esc.
Glen
Oct 24, 2005, 10:19 PM
RPV builder & operator
Pierre Audette's Avatar
Nice! What size is it, and what's the finish?
Oct 25, 2005, 12:44 AM
Flying RC Since 1968
DangerBird's Avatar
Great Paint Job! Bluecore? Plans?
Oct 25, 2005, 06:04 AM
Or am I...
www.3dfoamy.com PLans
Oct 25, 2005, 07:17 AM
please post how you did the finish/paint job. looks verry good....
Oct 25, 2005, 11:36 AM
JohnVHRC
JohnVH's Avatar
Great job!! Now, Imagine how much better the Laser cut Kit with the GForce wing flies
http://www.3dfoamy.com/Citabria.htm
Latest blog entry: a 7yr olds first RC flight!
Oct 25, 2005, 12:00 PM
prop wash
biggy boy's Avatar
Yup the Gforce wing for the Citabria would be real good!
Yes for sure it would fly much better with the laser cut 6mm Depron.
I'm in the process of building one with the depron, it will fly Great!!!
With half the fuse weight of the 1/2 inch blue SM.
Glen
Oct 25, 2005, 12:10 PM
prop wash
biggy boy's Avatar
Painted it with Krylon H2O water based spray can.
Did not care for it much. The paint did not stick well to the SM foam,
it would peal off when I used tape on it to mask. I also used frisket sheet to mask off the pattern, it did not peal the paint as bad.
Maybe it would work better on Depron.
I have switched to Testers acrylic paint in the little jars and air brush it on.
I have only used the testers on the Depron citabria that I'm making and it sticks good.
The H2O did not cover well and needed six coats too much paint!
I woulds suggest eather to buy a kit from 3D Foamy or if you do make it from the plans, use Depron. Much lighter in the 6mm then my 1/2 inch.
The 1/2 inch plane flys fine, just may not be able to do all of the normal 3D stuff, the lighter one can do.
Oct 25, 2005, 12:27 PM
JohnVHRC
JohnVH's Avatar
Try the Krylon Short Cuts, covers better and and goes on thinner.
Oct 29, 2005, 02:44 PM
prop wash
biggy boy's Avatar
Wana see the picture of my Citabria after charging it?
Here is what it looks like now after charging the lipo.
Oct 29, 2005, 02:51 PM
JohnVHRC
JohnVH's Avatar
Holy cow!! I never charge my LIPO's on the plane.
Sorry to see that beautiful bird burned up.
Oct 29, 2005, 02:53 PM
Use the Force!
LBMiller5's Avatar
Never, never, never, charge batteries while they are in the plane! Never charge Li-Po's while unattended. Treat Li-Po's like 2-year old children. While charging, never let them get out of your sight for more that 30 seconds!
Lucien
Oct 29, 2005, 05:41 PM
prop wash
biggy boy's Avatar
Lucien
Ya after 3 years of using lipos and never having a problem, I screwed up and let my guard down I usualy charge outside and on the concrete no plane.
I was thinking of mounting the left over wing tip on a plaque and present it to myself as the idiot of the year award
All of the electronics were brand new
the battery was two months old.
And had puffed a bit. NO MORE PUFFY BATTERYS!!!
Glen
Nov 27, 2005, 04:28 PM
prop wash
biggy boy's Avatar
Hi
Ok got around to finishing and flying the replacement for the one that went up in smoke.
This one was made with 6mil Depron, as per the plans.
Flew it today for the first time.
It only weights about a 2 oz. less then the first one, that was made of 1/2" foam.
Now I can get back to trying to learn how to fly 3D
Glen
Nov 27, 2005, 06:31 PM
Re-kit'r extraordinair
rickhtoo's Avatar
Yep, and cheap too. Comes in the little 'short' cans, and less than $2.00 at Michaels. I bought some recently, and also see Plasti-Cote Odds 'n' Ends right next to it so got a few of them also. Even though they are both fast dry enamel, the Plasti-cote will eat the foam, where as the Krylon will not. Why that is, I do not know... Regular Krylon eats foam also, so I wonder what they did to the short cuts to make it safe? Works good though.
Rick
3D Foamy Citabria... ericdod 3D Flying 9 Oct 18, 2008 12:53 PM
Sold APEX 3D Foamy Custom RTF just add RX rcdude01 Aircraft - Electric - Airplanes (FS/W) 10 Aug 14, 2005 08:45 AM
3D Foamy Citabria: Video ericdod Foamies (Kits) 0 Jun 28, 2005 06:06 PM
3D Foamy Mini-Citabria.. 1/4 pounder MorrisM 3D Flying 38 Apr 25, 2005 04:02 AM
