Oct 01, 2005, 02:34 PM
Blue skies forever!!
spitfirem9's Avatar
"Sprinter" spoilerons w/ elevator mixed in?
I'm setting up my Reichard "Sprinter" hotliner that I bought from www.soaringusa.com. I'm going to install an Aveox F-10 w/gearbox, 80amp ESC, 10-cell TP 2400NiMh battery. This baby should be a rocket!! Anyway, do you guys recomend using the ailerons as spoilerons to slow down easier for landings? If so, how much up throw should I dial in? Also I've read that some guys mix in roughly 10% of UP elevator to compensate for when the spoilerons are deployed. Is that a good idea and the right amount? Thanks for any advice and info you could give me.
Jeff
Oct 01, 2005, 05:56 PM
rcelectfly's Avatar
Yes, the ailerons should both go up for landing control. They should go up as much as reasonably possible with your linkages or about 45 degrees up.
10% is about right to start with but the elevator compensation should go DOWN not UP. You will likely need to adjust the compensation after test flying. Also, don't wait until landing to test the compensation. Try it with some altitude first.
Chuck
Oct 04, 2005, 11:40 AM
spitfirem9's Avatar
Thanks Chuck for the info. I'll give it a try.
Jeff
Oct 04, 2005, 02:43 PM
Single-task at best...
tim hooper's Avatar
Jeff,
I've just put a Sprinter together for a clubmate. There's a thread here;
https://www.rcgroups.com/forums/show...ight=sprinter+
I was surprised to find that there was little, if any, trim change when the spoilerons were deployed.
tim
Programing Spoilerons w/ Futaba 8U and Hitec 555 ferradas Electric Plane Talk 27 Jun 14, 2002 04:42 PM
Where did you mount the elevator servo in the Twister Al P High Performance 12 Jan 02, 2002 08:28 AM
Aileron/Rudder/Elevator w/ 2 mixed servos? hardlock Power Systems 13 Sep 29, 2001 02:42 AM
Elevator autopilot in a sailplane ? William A Power Systems 9 Jul 26, 2001 10:05 AM
Rondo 400 w/Hitec 3SS in Zagi? byoung Foamies (Kits) 0 Jul 25, 2001 07:52 AM
