New Product
SIYI A8 mini 4K AI Mini Zoom Gimbal Camera - 1/1.7-inch 8MP AV Output
Dear Community,
SIYI Technology releases its A8 mini gimbal camera, lightweight and elegant, carrying a 4K 1/1.7-inch Sony starlight night vision sensor. A8 mini comes with powerful AI identify and tracking based on neural network professing unit and supports max 6X digital zoom. Ethernet and HDMI output are compatible with both SIYI links and third-party links. And CVBS (AV) output for analog FPV. A8 mini can be widely used for enterprise drones, UGV, USV, robotics, RC hobby planes and FPV drones. Pre-sale will start with attractive pricing and the mass production lot will be ready very soon. Welcome to inquire anything you are interested in A8 mini! A8 mini Official Store Link Technical Specifications Overall Model: A8 mini Video Output Port: Ethernet, HDMI, CVBS (AV) Control Signal Input Port: S.Bus / UART / UDP Control Signal Output Port: S.Bus Working Voltage: 11 ~ 25.2 V Power Consumption: Summit 12 W Working Temperature: -10 ~ 50 ℃ Dimension: 55*55*70 mm Weight: Approx. 95 g Gimbal Angular Vibration Range: ±0.01° Controllable Pitch Angle: -135° ~ +45° Controllable Yaw Angle: -160° ~ +160° Controllable Roll Angle: -30° ~ +30° Camera Lens: 6X Digital Focal Length: 21 mm Image Sensor: Sony 1/1.7-inch, 8 MP effective resolution Aperture: F2.8 FOV: 93° TF Recording Resolution: - 4K (4096 x 2160) @ 25 fps - 2K (2560 x 1440) @ 30 fps - 1080p (1920 x 1080) @ 30 fps - 720p (1280 x 720) @ 30 fps Supported File System: FAT32 (exFAT will be supported later by firmware update) Photography File Format: JPG Video File Format: MP4 Supported MicroSD Cards: MicroSD Class10, max 128 GB White Balance: Auto Videos
Cool camera!
Is the 93 degree FOV horizontal or diagonal? Does HDMI output has any lag or is live view with no noticeable lag? Does it have WDR? Do you have a sample video? |
Thanks for clarifications.
FOV is important for FPV flying and I would say 93 diagonal is a little too small. Can there be options for different lenses FOVs at checkout? WDR is also important for FPV, without it flying with the sun in view makes everything dark or overexposed. |
I can see that HDR is mentioned in camera specification (which is probably for photos only?) so hopefully WDR is also possible to implement into firmware (for video)
Walking with SIYI A8 mini Gimbal Camera 4K Original Footage (shot with engineering sa
Here comes the first sample footage!
Hi, very interesting product and it looks promising. On the FPV video out, do you have a adapter cable to connect to the VTX? What camera functions can be controlled via Control Signal Input Port: S.Bus / UART / UDP?
Also, on FOV, the 93 degrees us good for cinematic shots where you want a realistic view of what you are shooting and where I would consider using this product. I would only use wide angle for my racing drones where you want to see as much a possible and don't care about perspective. |
Based on the video, the FOV is ok-ish. Ordered one, will see how it goes.
I think FOV is great to use with headtracking or manual pan/tilt controll, as its much easier to see details of area around with lower FOV. And as this is pan tilt camera, imersion can be achieved with mooving camera around
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| New Product | DJI Mavic 2 Zoom 3-Axis Gimbal Camera 1/2.3" CMOS Sensor 2x Optical Zoom Foldable RC | scousethief | Vendor Talk | 0 | Jan 23, 2019 08:10 AM |
| Authentic DJI Osmo+ Handheld Gimbal (4K Zoom Camera) $648.95 | Noel. | Vendor Talk | 0 | Sep 27, 2016 03:43 AM | |
| Discussion | camera signal causes "zoom in" effect on FOxtech CE OSD 1.2 AV OUT signal | raschemmel | FPV Talk | 1 | Oct 27, 2010 02:24 AM |
