Question
Cheap BL setup for foamies
With so many models on the market which use cheap Mabuchi 380, Speed 400, Permax 400 and 7 to 8 cells, it is worth looking for a cheap BL tuning setup.
Which BL combo (motor & ESC) delivers approx. 60% more power (at the same power consumption as a Permax 400, 6V) on 2 Lipos and a Günther(ZAGI)prop (or similar sized prop) and costs less than $67USD? Does anybody know the answer - or want to know the answer? ![]() ![]() |
Do tell!
here
I cant tell you much about this motor as its being shipped to me, and yet I dont have it, but its sure is a great price ![]() Good luck |
Well, the outrunners mentioned above are really no direct Speed 400, Permax 400 replacements.
I just ordered two more Align BL 400 SF with CC Thunderbird 18A ESC for $66.55 at www.allerc.com Here you can see the test diagrams (using a Kontronik PIX1000 18A ESC) at 7V, 8V and 9V (I assume the CC Thunderbird 18A will work fine too with this motor): |
i'm being patient, but am in a hurry, (ha)Quote:
Honest, I'm anxious, but I will wait patiently for your "findings". thx, LarryR ![]() |
Align BL
My RCER Warp 4 died near the end of a flight 2 weeks ago. It would no longer spin up - it just stuttered and then quit. So, I pulled it out and called up All e RC where I bought it and they took it back without a problem and sent me a replacement. In the meantime, I also saw the good price on the Align motors and their performance data. I ordered the 2500 kV one and installed it in my EZ. So far - I am extremely pleased. I flew with it yesterday and can report that the motor puts out nearly the same power but my run time has gone up by a good 5 minutes. I ran my usual flight routine with a good mix of aerobatics for just at 20 minutes. I still had 700+ mAh left in the 2600 mAh pack.
![]() Jurgen is right - if you are considering a BL upgrade for your EZ, you should look at the Align option. Note the motor shaft is 1/8". My 3 mm prop adapters would not seat properly so a new prop adapter was purchased at a LHS. I would go for a bigger capacity ESC though than the 18A. It is easy to pull over 20A with a 6X4 prop, if you are using 3 cell LiPo packs like I am. |
Jurgen
What props do you suggest with that combination??
Cheers Numb Thumbs ![]() |
2S and 3S please!
Or the full numbers so I can put it into MotoCalc myself..
Cheers Numb Thumbs ![]() ![]() ![]() |
sourcesQuote:
thx, LarryR ![]() |
Thread Tools | |
Similar Threads | |||||
Cheap training setup for + shift? | echaban | Radios | 5 | Feb 19, 2005 10:21 PM | |
BL setup for Flashback, Tantrum, Switchback & SmoothE | DC Ross | Parkflyers | 1 | Apr 07, 2004 02:23 AM | |
BL setup for Flashback, Tantrum, Switchback & SmoothE | DC Ross | Power Systems | 0 | Apr 06, 2004 01:08 AM | |
Need BL setup for 3DX - NOW !!! | localbuyer | Power Systems | 0 | Nov 17, 2003 10:58 AM | |
Cheap brushless setup for Kyosho F16? | megawatt | Electric Ducted Fan Jet Talk | 6 | Apr 25, 2003 11:17 AM |
