Aug 19, 2005, 01:00 AM
Balancing a 4 Blade Prop??
Hi Guys,
I'm building a P-51 and bought a big APC 4 blade prop for it(15.5" by 12" pitch. I'm going to round off the tips and bring it down to a 13" prop.. I normally use the magnetic prop balancer for my 2 blade props. However, how can you balance a 4 blade prop. It's kind of a confusion question - do I balance it just like a 2 blade? How can I tell when it's all balanced out?
Aug 19, 2005, 10:41 AM
BuzzBomber's Avatar
It seems complicated, but it's really simple. With a 2 blade prop, you want it to stop horizontal typically. This could(it's a bit of a stretch) be misleading, because if it always stops in the same horizontal position, the hub could be heavier on one side(nitpicking, I know). The other way is to observe if the prop stops in a different position every time, without dropping a blade after slowing down. With 3+ blades, you follow that last convention: it should stop in a different position every time when balanced.
Mustang with 4 blade prop RMason Parkflyers 31 Feb 22, 2003 10:21 PM
GWS 4 blade prop info please The Blue Max Parkflyers 2 Sep 28, 2002 11:10 PM
4 blade prop grr1941 Electric Plane Talk 3 May 17, 2002 04:47 PM
3 and 4 blade prop balancing shy-talk Scale Kit/Scratch Built 1 Mar 09, 2002 03:51 PM
GWS 4 blade prop Bob Reynolds Parkflyers 1 Mar 08, 2002 04:55 PM
