Jan 17, 2022, 07:50 PM
Held by Grace
BDOG1's Avatar
Build Log
Magnum Models DAW KA-6 3M build
Now that I have finished my Daw mini war bird build, and am all warmed up on that style build it is time to finally get started on the KA-6 .
First step : I spent the afternoon cleaning off my work space {it's amazing the lost parts you find }
There is Alot of foam goodness stuffed into that box ,Its nice to be able to spread it all out in one spot - It's ok if you do not have a huge work area as the wings build in sections and you only need 58" space when you join the tips to the inner sections .
Jan 17, 2022, 08:21 PM
Held by Grace
BDOG1's Avatar
To get in the spirit :
Ka6s at Los Banos (4 min 44 sec)
Jan 17, 2022, 08:22 PM
It's not going to build itself
TRISME's Avatar
Subscribed!
Jan 17, 2022, 08:33 PM
F3Foamie Pilot
Slopemaster's Avatar
Wow, you didn’t even take a breather.
Jan 17, 2022, 09:21 PM
glider304guider's Avatar
Your a building machine!
Jan 17, 2022, 09:45 PM
Held by Grace
BDOG1's Avatar
So many planes
So little time
Jan 18, 2022, 05:38 PM
Held by Grace
BDOG1's Avatar
Great pictures Ken !
I have been to 2 out of 3 of those place...maybe 3
Is the first picture taken in Wilson KS ?
Jan 18, 2022, 09:07 PM
Held by Grace
BDOG1's Avatar
Let’s start the build
First steps :
I like to start out by working on the wings .
I pull out ,identify and mark all the pieces ( Spars ,sub trailing edges , trailing edges left and right sides )
Jan 18, 2022, 09:20 PM
Are you going to add flaps to yours or keep it stock?
Jan 18, 2022, 09:34 PM
Held by Grace
BDOG1's Avatar
I will be adding flaps ,the last time I flew my buddy’s unflapped Ka-6 over Lake Erie in Cleveland I had a difficult time getting it slowed down and landed , was a Hot arrival 😬
Jan 18, 2022, 10:30 PM
What size flaps? I am about to that point with mine.
Jan 18, 2022, 10:51 PM
F3Foamie Pilot
Mine has spoilers. They definitely help.
Jan 18, 2022, 11:05 PM
F3Foamie Pilot
Make sure you install the aerotow setup. Dave’s aerotow mechanism is simple but effective.
I aerotowed mine a few times, works great.
And for gods sake, make the whole radio removable. I still have the original dead battery in the nose. It’s just ballast now. I now put a new battery in a cutout right on the CG. When I built my KA6 back in 02’, I had not yet started building my EPP gliders with removable radio gear. Fortunately I finally saw the light.
Jan 18, 2022, 11:11 PM
Held by Grace
BDOG1's Avatar
Flaps
Trisme : who has built 2 had posted elsewhere that his flaps started 11.5 from the root which gives you a 24” flap
Tom: is there a reason why you didn’t go full span with the flaps ?
Build Log Magnum RC Models DAW 48-inch warbird build Roy G Biv Slope Soaring 30 Nov 12, 2023 10:15 PM
Build Log Magnum RC Models DAW 48-inch Warbird build log - Kawafoamie Ki-61 Roy G Biv Slope Soaring 103 Dec 17, 2020 08:45 PM
Discussion DAW Ka- 6 : available again BDOG1 Scale Sailplanes 1 Nov 15, 2019 10:38 PM
DAW Ka-6 Winch tow? rgteel Thermal Soaring 2 Dec 31, 2004 01:50 AM
