Jan 12, 2022, 11:53 AM
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
Question
Silver Pens on Plastic?
I'm looking to highlight some detail on a Guillows P38; can anyone provide success stories for using silver pens to apply to plastic such as the wheels and the boom guns? This would be a nice touch.
Some recommendations for a silver pen that works would be appreciated. Thanks!
Jan 12, 2022, 02:37 PM
AndyKunz's Avatar
What are "silver pens?" Amazon has lots of pens made of silver. Are you talking about Sharpies the have silver ink?
Andy
Jan 12, 2022, 03:33 PM
ruff1's Avatar
The ones that lay down a metallic coat on a wide variety of surfaces.
Jan 12, 2022, 04:19 PM
JimboPilotFL's Avatar
There are paint pens that you can get at stores or online.
Jan 12, 2022, 07:37 PM
Closed Account
If you can find them, the Testors/Pactra paint pens are paint applicators with a foam brush built in. They work okay for the ABS type plastic used in gummy band kits.
I don't recommend using Sharpies on ABS as it will rub off (at least, most of it will).
BTW, 'boom guns' on a P-38? The guns were in the nose pod, not the booms. Besides, don't most guns go "Boom"?
CD
Jan 12, 2022, 09:41 PM
ruff1's Avatar
CD,
Maybe I need a P38 lesson...
For sure on the nose guns, there are dowels in the kit to use for those.
I'm referring to the object on top of the booms over the wing area. Have a look at the picture, they sure do look like guns.
Jan 12, 2022, 09:51 PM
ruff1's Avatar
Well duh...
I found an exploded view, this is the area where the supercharger and other related engine components are located.
As you were...
Jan 13, 2022, 02:38 PM
That is the turbocharger. The supercharger was in the cowl.
Jan 13, 2022, 06:50 PM
Closed Account
(quietly sinking down below his computer desk, not knowing which is the turbocharger and which is a supercharger)....Umm, mea derpus?
Jan 13, 2022, 09:22 PM
Duane, LSF IV
Wazmo's Avatar
A turbocharger is typically powered by a coaxial turbine in the engine exhaust.
A supercharger is typically powered by a mechanical connection to the engine crankshaft, or an electric motor.
https://en.wikipedia.org/wiki/Turbocharger
https://en.wikipedia.org/wiki/Supercharger
Help! Using CA on plastic to plastic plane parts Jack_K The Builders Workshop 4 Sep 29, 2021 07:41 PM
Discussion Paint ABS plastic to Apple MacBook Sandblasted+Anodized Silver? wahaha686 Painting and Finishing Tips 2 Apr 09, 2016 06:09 PM
Discussion Rcgf 20 little thin plastic on carb heat block, BenBen123 Fuel Plane Talk 16 Sep 24, 2015 12:03 PM
Discussion Silver Conductive pen tobiasp DIY Electronics 2 Oct 12, 2006 11:00 AM
