Jan 11, 2022, 01:20 AM
New Habu 102 from Horizon Hobby
Gentlemen,
Wouldn't this be a great seller:
New fiberglass ducted fan Habu with complete ducting, sized for 90 or even better 105mm fan, comes complete with retracts, gear doors, nice struts, servo covers. Enough internal room to easily accommodate 12S and still have wing loading similar to a Habu32. Top speed with 8S recommended eflite equipment exceeds 150mph.
I just think this would sell so well as it would have no peer in the market. There's very few ducted fan fiberglass jets on the market today. The ones available are not built for top speed.
Thoughts?
Andy
Jan 11, 2022, 05:53 AM
2022 EDF Jet Jam, June 9-11
Robert Belluomini's Avatar
Sadly, It will never happen.
Jan 11, 2022, 09:30 AM
Why do you think? This would sort of be like a smaller BVM Electra but with some included equipment...the kind that come with fms or freewing foamies.
Jan 11, 2022, 09:47 AM
Multi-Platform Pilot
barracudahockey's Avatar
I agree with Bob, it would be awesome but I doubt they will do it.
Shame really
Jan 11, 2022, 11:50 AM
Shame really
It is a crying shame. I don't understand why when they responded it as Habu32X that they did not add gear doors or nice landing gear struts. We get these with foam jets. The investment was already there.
There is so much potential with the Habu32 that could be explored with something made to go really fast.
Jan 11, 2022, 12:41 PM
world's slowest builder
Air-Jon's Avatar
This would be a great jet! With proper ducting, 90mm would be plenty, but the option to go 100mm would be nice as both E-jets Jetfan and Wemo make nice 100MM fans.. Could be set up on anything from 6 to 12S. Make it right between the size of the Habu 32 and the Electra. I would vote for a top mounted Horz stab like the original Habu. Light lay-up fuse and built up wings and stabs would be just fine.
Jan 11, 2022, 03:16 PM
Could be far faster than a habu32 with more thrust and drag reduction from factory. Horizon was proud of the Habu32, it was the cover of the catalog
Jan 11, 2022, 03:24 PM
Mainly because getting something like this made is becoming more difficult every year with the Chinese Factories. Foam is all done on the front end and takes far less skill to assemble and paint.
Ready to fly models are what people want. Assemble, add Rx and Battery go fly, it's as simple as that.
Foam sells in greater numbers and costs much less to make.
Trust me I would be ecstatic if they made this model.
BTW you title should probably have "What if" as part of the title. "New" is misleading.
Jan 11, 2022, 05:03 PM
Air-Jon's Avatar
Faster in stock form? If they offer an 8S version stock, certainly it would be faster than a 6S stock Habu 32 (although people flew 32s on 7s on the stock fan/motor and they were quick!) at least half the people buying will not care about the stock setup and will be buying it for an upgraded aftermarket EDF. As far as being faster than the Habu 32 overall...it's likely be possible, but not by much. I believe the record for the Habu 32 was 204 averaged for upwind/downwind.
If it were light and had ample battery shifting ability (battery tray between the intakes) and an long fan access hatch, a modeler could quickly switch between a hot 6 or 12S setup as long as they have an HV SC. Super lightweight 6S for small fields and slower freestyle aerobatics (and single battery practicality) and a 12S setup for speed runs. could use the same 6S 5000-6200 packs, and just add a second pack for 12S.
Jan 12, 2022, 08:19 AM
Yes, faster in stock form than the Habu32 because of provided landing gear doors, servo covers, and other Aerodynamic bits to really make it faster. I have a 32 that is 8S and I think it's at the weight limit with 5000 packs. A larger Habu could take that 8S and be faster than mine out of the box via Aerodynamic improvements.
Jan 12, 2022, 09:14 AM
Build'em and Crash'em
Ken Lapointe's Avatar
Sounds like you want a Taft Cobra.
Jan 12, 2022, 10:28 AM
Air-Jon's Avatar
I was thinking the same. Composite the size of a Taft cobra…but no foam. I would keep the looks more like the Habu…but maybe tweaked slightly. The Habu at least had an original style vibe going. With the full bubble canopy, wide nose and Vert profile…..particularly the original foam Habu style with a shoulder mounted horz stab ( which was ahead of it’s time as all the new turbine sport jet designs have adopted the shoulder stab)
A larger size would also allow Micro servos mounter directly in the stabs. High quality Micros like Hitec D-89s could handle the job no problem…or use the quality thin flat mount micro servos. No more long pushrods.
Jan 12, 2022, 05:05 PM
It's foam and pretty heavy. I have one! Pretty small battery area if I recall
Jan 12, 2022, 08:22 PM
Air-Jon's Avatar
That is one of the issues with foam, the thick fuselage robs battery space. The design need a wide nose like the Habu, and space between the intakes for a second pack. It should not be designed to copy a Bob Violet jet (as the cobra did) as those are designed to work with saddle packs. It needs a wider nose and the fan further back to counter weigh the batteries and to make room or more space between the intakes.
Jan 13, 2022, 03:20 PM
Why don't you get the Composite FlexJet?
https://www.flexinnovations.com/prod...exjet-pro-arf/
New Product New Force RC 4S Capable 4wd 1/8 Brushless MT & Truggy at $299.99 From Horizon Hobby hbx12891 Off-Road Vehicles 16 Apr 29, 2019 03:59 AM
Discussion Earn Horizon Hobby Credit - Work with Horizon from Home!! Nixus Vendor Talk 20 May 31, 2018 05:30 PM
News Three New Aircraft From Force RC - Horizon Hobby Matt Gunn Electric Plane Talk 39 Dec 09, 2017 07:59 PM
Discussion New product: Msr S from Blade by Horizon Hobby SpekBo Micro Helis 2 Jan 06, 2017 08:36 AM
Discussion New Horizon Hobby Habu 2 - For SPEED FREAKS :) FLAME747 Foamy EDFs 5 Apr 17, 2012 09:04 AM
