How to get inverted in the first place??
I have a long way to go B4 im gonna go and cut the lanwn with my heli, but I was wandering how do you guys actually get your heli inverted in the first place
![]() I excuse myself if its a dumb question but we all start from somewhere. ![]() |
Not that I can do it with the real thing, but you can flip it forwards/backwards or roll it. Obviously using collective at the same time as cyclic.
Ideally - my opinion and only practiced on the SIM so far - you need to transition from hovering +ve pitch to 0 pitch to hovering -ve pitch smoothly as the heli transitions from nose horizontal to nose vertical to nose inverted horizontal.
If you think about it you want to spend little time with the heli nose vertical and you also do not want any lift from the main rotor at that stage of the 'flip' or your flip becomes 'stretched' as the heli is pushed along horizontally. The key seems to be to get enough momentum into the flip early on and then back on the pitch thru 0 and into -ve as the nose comes over. As I said, I can do this on Reflex XTR but I'm struggling when it comes to trying this for real. |
I have FMS but no way of doing inverted flight with it. I also have access to a Blade CP that the owner cannot fly and wants me to try and fly it inverted with no cost to me if it breaks
![]() I do want to be at least semisuccessful though and dont want it to break until i at least get all the way upside down. |
yes it can. I used it with a Walkera 4 channel radio until I got the cable for my eclipse 7. It doesn't have seperate pitch and throttle channels, only pitch. Just flip the thing over and drop the throttle stick and it will work. The only problem you might have is that if you're using the dragonfly model you can't actually get inverted because it doesn't have fast enough cyclic response.
Just grab the T-Rex model from trextuning.com and try it ![]() |
Seriously, we had this happen. |
and the video is on www.mrchc.org.au
![]() If I'm not flipping inside within a year from now, you can kick my but! ![]() I did see the vid too. I was always curious why someone with that sort of experience was starting upsidedown. ![]() |
i'd definitely recomend entering with a 1/2 roll, if you do a flip either front or back the risk of the heli starting to "run away" in the flip is high ... in a roll you allways stay at one orientation e.g. tail in to start and the heli moves sideways if not done rolled on the spot rather than come howling at you or disapearing on the horizon
A year? Bet you are flipping etc within 3 months. Might have to get you flying Johns Raptor on a buddy lead as well - you'll get a lot of confidence with that. I start with a 1/2 roll as well but I learnt tail in inverted first, some people find nose in inverted easier and they do half a flip. |
Thread Tools | |
Similar Threads | |||||
Help! | X400 or Trex - How to get the belt into its place??? | Eddiemoth | Mini Helis | 4 | Feb 09, 2006 12:33 PM |
why can'y i get all in one place | eran_k | Electric Plane Talk | 5 | Mar 19, 2005 02:29 AM | |
How to get started in DLG | tjcooper | Hand Launch | 24 | Dec 05, 2004 09:06 PM | |
How to get started in Li-Polys? | D W | Batteries and Chargers | 13 | Jan 02, 2003 12:34 PM | |
How to get started in Li-Polys? | D W | Parkflyers | 7 | Dec 24, 2002 07:11 PM |
