Oct 08, 2020, 11:01 AM
pretty plane!
Oct 09, 2020, 02:39 PM
Petefoss's Avatar
Hi Frank,
What RX and servos do you use? Would a 1S brick from a HH bind and fly's work? Or do you use rotary servos vs. linear?
Oct 11, 2020, 11:02 AM
burkefj's Avatar
This is too large for the brick, servo strength not sufficient for the surfaces, I do use 1s but use hitec HS-65HB servos as they run fast on 1s compared to others.
Frank
Originally Posted by Petefoss
Hi Frank,
Oct 11, 2020, 03:23 PM
Petefoss's Avatar
And the rx? Most shut down at around 3.5 V!
Oct 11, 2020, 03:50 PM
the kitty litter of rcgroups
rdwoebke's Avatar
1S is pretty typically used by DLG folks these days. It typically sits about 4 volts or so with just servos and I set my alarm at 3.8 volts. Most receivers are fine with that setup.
Ryan
Latest blog entry: Supergee wing mount pylons
Oct 11, 2020, 04:40 PM
Petefoss's Avatar
Thanks Ryan. I was thinking unconsciously about 1S including a motor current too where it's super easy to drop below threshold and brown out. Not used to thinking about just rx and servo power.
Oct 11, 2020, 04:50 PM
burkefj's Avatar
These flights are fairly short, so I've done maybe 12 flights in a day on one charge of a 1s 500mah battery and put back in maybe 100 at the most, so well above even 3.8v...
Oct 14, 2020, 09:02 PM
Aircraft Life
wunkus's Avatar
I took a Flite Test Explorer kit and turned it into a rocket glider. It still needs some tuning.
Rocket-Powered: Flite Test Explorer (5 min 35 sec)
Oct 15, 2020, 01:33 PM
creative and ingenious!
i have the same prolem taking my grandchildren to watch me fly
Oct 15, 2020, 11:48 PM
burkefj's Avatar
What is your weight ready to fly and what motor are you using?
[QUOTE=wunkus;45651785]I took a Flite Test Explorer kit and turned it into a rocket glider. It still needs some tuning.
Oct 16, 2020, 07:57 PM
Aircraft Life
wunkus's Avatar
714 grams including spent motor casing. Each flight has been with an Estes E12.
Oct 18, 2020, 03:50 PM
burkefj's Avatar
Ah, that's pretty heavy for an E-12, I was going to suggest a longburn motor, but that's way too heavy for the E-6's I prefer, I keep my weights less than 340 grams for that motor....E-12's should boost a 400 gram model to maybe 300' or so with draggy high lift wings like on a glider. The 32mm G-12 would work but it's quite a bit heavier at 130 grams for the motor, but it will boost 780 grams up to around 500' or so but quite a bit more $$ per flight. Wish I had a better suggestion for you.
QUOTE=wunkus;45667285]714 grams including spent motor casing. Each flight has been with an Estes E12.[/QUOTE]
Oct 19, 2020, 05:24 PM
burkefj's Avatar
Upscale Orbital Transport R/C rocket glider G-12 flights (4 min 40 sec)
Oct 19, 2020, 05:38 PM
very shuttle like, i love it!
Oct 21, 2020, 08:50 AM
Aircraft Life
wunkus's Avatar
Launched with an F motor!
Rocket-Powered: Explorer on an F-15 (4 min 44 sec)
Discussion I have some RC rocket gliders up For Sale jfruge Rocketry 0 Jul 10, 2007 03:47 PM
Discussion anyone else see fred in an rc heli mag? helifrek Electric Heli Talk 9 Dec 29, 2005 09:10 PM
Reloads available for RC rocket launched gliders red arrow Product Announcements 0 Oct 16, 2005 10:10 AM
Anyone else doing an RC club at school? JTinCT Electric Plane Talk 2 Sep 25, 2004 11:16 AM
Anyone else catch "the best RC pilot in the county" tonight? Mikey C. Electric Plane Talk 0 Oct 29, 2003 11:19 PM
