Hobbyking - Updated Rhino and ZIPPY Lipo Batteries
Check out the Rhino and Zippo lipo updates...
Hobbyking Lipo Update
Hobbyking reached out and want me to share this info...
Rhino Lipos
Known for their high and consistent discharge rates, the Rhino line of RC batteries is your low-cost alternative for high-performance LiPo batteries. Utilizing our patented technology, energy loss due to excess heat is greatly reduced which in turn, greatly increases the efficiency and run-time of your LiPos.
Rhino batteries also leverage high-conductivity electrolytes, which when combined with its inherently low internal resistance, allows for incredibly high outputs that truly pack a punch. Available in a wide range of capacities and dimensions, Rhino batteries can be used for most applications including RC cars, planes, boats, helicopters, and drones.
CLICK HERE TO CHECK OUT THE UPDATED RHINO LIPOS
Zippy Compact Lipos
The ZIPPY line of RC batteries is known to be one of the most affordable, yet high-performance brands on the market today. The signature series "COMPACT" offers LiPo and LiFePo4 batteries at smaller sizes while still retaining high capacities and discharge rates.
The smaller dimensions make ZIPPY perfect for models with limited battery space or ones that require a specific configuration. Available in both hard and soft packs, ZIPPY batteries can be used for RC cars, planes, boats, helicopters, and drones of all shapes and sizes.
CLICK HERE TO CHECK OUT THE UPDATED ZIPPY LIPOS
Dec 07, 2021, 02:31 PM
pull up -- PULL UP!!!
Specs and color are real close to RCBattery Liperior. Same batteries, different labels?
Dec 07, 2021, 02:51 PM
Do not insult Richard like that please
Dec 08, 2021, 01:12 AM
Too heavy...
6s Zippy compact 3300 60C is 560gr :-(
Vs. 6s Hrb 4000 60C, 596gr ....
Vs. 6s SMC 3600 470gr... ;-)
Dec 08, 2021, 11:04 AM
Aio_1's Avatar
Some of the masses are very high. So much so that one might suspect some of the higher discharge rate packs, simply have their capacity understated to allow a higher C rate be advertised. There's absolutely no benefit to anyone buying such a pack but anyone just looking at capacity and voltage but not paying attention to mass could be fooled.
On the other hand, have a look at these two packs side by side:
ZIPPY Compact 1500mAh 3S 25C Lipo Pack
Spec
Capacity: 1500mAh
Voltage: 3S1P / 3 Cell / 11.1V
Discharge: 25C Constant / 35C Burst
Weight: 143g (including wire & plug)
Dimensions: 106x34x21mm
Balance Plug: JST-XH
Discharge Plug: XT60
Price: 12.06
ZIPPY Compact 1500mAh 3s 40c Lipo Pack
Spec
Capacity: 1500mAh
Discharge: 40C Constant / 50C Burst
Weight: 139g (including wire, plug & case)
Dimensions: 107x34x20mm
Price: 12.16
These two packs have the same voltage and capacity spec, and use the same connectors. Dimensionally they are almost, but not quite, identical. The 25C pack weighs 4g more and only costs 0.10 less. The 40C pack has the same capacity but will presumably hold voltage better and last better for any given load since it's operating further within it's discharge limits. It also weights less and the only penalty based on the information available is a paltry 1% additional cost.
Why on earth would anyone who understands the specs buy the 25C/35C version???????
In general these packs seem to have disconcerting variances in energy density, discharge rate and mass.
Dec 08, 2021, 12:06 PM
Yes, for me consistency is a huge and very important indicator of quality.
These brands are really just relabeling outlets from whatever hodgepodge of actual makers' bulk clearance sales.
Sometimes you get lucky...
Dec 20, 2021, 05:29 PM
JohnVHRC
JohnVH's Avatar
Great batteries, I have both!
Latest blog entry: a 7yr olds first RC flight!
Dec 21, 2021, 02:25 AM
I am a bit skeptical of Rhinos, and even moreso of Zippy Compact.
Re Rhinos, I have :
1.) two 4S 2200s - experience after many cycles - actually very good. No complaints. They were super cheap too, so value for money, given what is available to me here in Germany, is flat out unbeatable IMVHO, period. They were like €16...
2.) two 4S 3300s - experience after many flights is that these are basically Graphene level quality. They are heavy, and frankly absolutely top quality lipos. As good as they come.
And 3.) three 6S 4000s. One showed up defective, and HK - to their credit - sent me a new one. I revived the bad one, kind of, but it is dodgy and out of balance, AS IS the replacement. So of the three I don't totally trust two of them. The replacement was giving me dodgy cell readings in flight - so it was having unusually high voltage sag for a nearly new lipo. Just a Taft Yak 11 - so no high-power EDF or anything..
So anyway, I would buy more 4S, but I am wary of the 6S. I did buy four more 4S 2200s, as well as two 3S 2200s. Have not used them yet though.
Re Zippy Compact:
I have two of the 4S 2200 60Cs, and they do not stay in balance as well as the Turnigy HDs. Same with a couple of 4S 2700s. I would try to not buy them again unless on sale... Keeping in mind Liperior and co are not available over here. Lipos from German shops cost 2-3 times as much as the better lipos from HK...(HDs, for ex..)
So anyway, I don't know if these two brands really have been improved, but in my experience and view, there is room for improvement... To me the Turnigy HD 60Cs are THE standard(again, what is available to me..), and in my experience but also based on what I have read of other peoples's experiences, they are not quite up to that level. To be fair though, the Rhinos anyway were incredibly cheap... OK for the 3S and 4S, but even getting a 6S 4000 for €32, well if it's dodgy, that's a bad deal if it's just a paperweight...
Dec 21, 2021, 06:10 AM
rgburrill's Avatar
I had 2 zippies go bad just sitting on the shelf. Puffed up so bad I was afraid of them. I will never buy another one.
Dec 21, 2021, 06:33 AM
Storage voltage or high SoC?
Dec 21, 2021, 10:51 AM
Powered by Flux Capacitor
I've found Zippies to have reasonable capacity and IR but have absolutely the worst balance wires made of stiff PVC insulation instead of soft silicone. Due to the stiffness, a few of the wires broke on solder join in the batteries and in once case shorted and almost caused a fire. Saving a few pennies using cheap stiff PVC is very foolish on the manufacturer.
Dec 21, 2021, 11:48 AM
Just remember. Battery specifics change over time. A Zippy today may be an entirely different battery from a Zippy years old. Little in common except the name. Most changes are for the better due to competition. Example, the new NanoTechs (+) are greatly improved over the originals.
Dec 21, 2021, 02:51 PM
How is a question an insult?
Question Anyone use Turnigy,Rhino or Zippy Lipos? hog2soar Electric Sailplanes 12 Jan 05, 2011 04:43 PM
Discussion Hobbyking-Zippy Flightmax, Rhino and Turnigy WAGliderGuy Vendor Talk 12 Apr 17, 2010 04:37 PM
Hobbycity: Zippy, Rhino, Turnigy lipos tjinguy Batteries and Chargers 132 Mar 29, 2010 07:51 PM
Are Rhino (Zippy) Batteries Any Good? Bookstar75 Batteries and Chargers 46 Oct 14, 2009 04:33 AM
Help! We need 3000 mah, 30c, 4s Zippy/Rhino lipos!!! Drew816 HobbyKing 5 Feb 17, 2009 01:20 PM
