RCPlaneStands.com Holiday Line-up!
Get the great stands while you can for the holiday season!
Check Out All the Plane Stands from RCPlandeStand.com
RCPlaneStands.com are made here in the USA buy a modeller just like you. Here are some current models to check out...
New Mid-Size Floor Model Workstation
Ultimate Floor Stand Workstation - This is our New mid-size floor stand model perfect for building larger and heavier aircraft. Made with mostly 3/4" Baltic Birch Plywood. Still small enough and light enough to take with you to the field for repairs. Endless angles and positions for all your needs.
Specs
  • Collapsed stand measurements Length 44" Width 30" Height 12" (collapsed)
  • Arms adjust for a 6" to 19" wide fuselage. (with the arms straight up)
  • New sliding support to extend out for larger aircraft.
  • The length of the fuselage supports can be from 15" up to 70" when fully extended. Fuselage can be much longer hanging over.
  • Holds up to 150lb aircraft easily. Comes with our Lever Handles and 1 1/4" fender washers so you can really crank the main rails tight to avoid slipping.
  • Removable 30" wide legs for easy transport.
  • Comes with 3" or 5" rubber wheels for stability in rough terrain.
  • Unfinished - Add your own finish, purchase a finish, or leave it bare.
CLICK HERE
MEGA Floor Stand
This Mega floor stand model is great for building very large aircraft in your shop. Endless angles and positions for all your needs. Optional accessories are available for even more versatility.
CLICK HERE FOR MORE INFO
New Benchtop Model
Adjustable, Light Weight, Breaks-down Quickly. This bench-top model is great for building on your workbench at home or taking it with you to the field for repairs.
Article RCPlaneStands.com Interview Jim T. Electric Plane Talk 4 Sep 13, 2021 09:18 AM
Mini-Review Micro FPV Drones Round-Up, Five for the Holidays XFrames FPV Micro Multirotor Drones 0 Dec 01, 2016 11:31 AM
3DFOAMY.COM's mini line up!!! with vids. 3DSWEPED#2 3D Flying 69 Jul 15, 2005 04:55 PM
