This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Dec 04, 2021, 07:41 PM
old4570's Avatar
What happened to the P1B-1 ?
Hmmmm , In deed .....
Ok the problem with the P1B-1 ...
The folding prop was the problem ..
A) The prop weighs too much
B) RPM and torque roll are effected by the heavy prop
C) Props hangs or folds , changes CG
D) The folding prop is a nasty cheap affair ...
So after a while I realized the folding prop was the problem and the model was hung up as an ornament .
The other day one of my FF models with a timed electrical system fell onto the floor .... Ding Ding !
And a idea flashed into my brain ...
For over a year I have been wondering what to do with the P1B-1 , mostly geared around some form of RC .
But what if I could ? Fit one of these timed electrical power systems ...
The battery fits in the tube , the timer / switch fits in the tube ..
I 3D printed a motor mount for the pusher set up .
The P1B-1 glides amazing without that brick of a factory prop .
The power system has been tested in doors , but not out doors ( very windy ) + the mod is barely 24 hours old .
It looks promising !
I was lucky , the 3D printed mount came out perfect 1st time out .
The motor is a 7mm DIA and the system uses a Lipo battery that is USB charged VIA the timer .
There is not enough power to pull vertical , but horizontal should be fine ..
Hopefully be some fun , especially as the rubber powered factory set up was a PITA .
What I need now !
Is to 3D print a nose cone that allows me to push the start button ..
My 1st attempt at such was a full fail
Discussion HELP Runaways on 4.1.1? What???? This isnt supposed to happen! Fidy$Trainer Micro Multirotor Drones 20 Mar 10, 2020 07:39 AM
Question What happened to my FreeFlight 1.31 board? Isaac96 Beginner Multirotor Drones 3 Jul 23, 2016 02:28 PM
Discussion Please What did I FRY or what happened? Weanuts Radios 1 Jan 20, 2016 11:46 PM
