Dec 03, 2021, 08:58 AM
Latitudes vs Attitudes
Bob Gaito's Avatar
Sand a sphere?
Right, sand a sphere- how would you finish sand a sphere without causing flat spots? I am sure that there are many methods out there-
Dec 03, 2021, 10:39 AM
Where's the pond?
patmat2350's Avatar
Lathe. Blanchard grinder.
Dec 03, 2021, 10:55 AM
Bob Gaito's Avatar
Sorry Pat-not enough info given- the "sphere is a half sphere, is made of polyester fiberglass, is 4" in diameter and is bonded to the front and rear(the pressure domes) of my Atlantis sub model. needs to be primed, spot puttied and finish sanded.
Sanding sponge? steel wool?
Dec 03, 2021, 10:58 AM
tghsmith's Avatar
size? a few ways to use a lathe come to mind,, could you drill it and glue in a stub shaft and chuck it up in a drill?
Dec 03, 2021, 11:00 AM
I don't want to "Switch Now"
pmackenzie's Avatar
A lathe might help, but a Blanchard grinder is used to make flat surfaces
Perhaps make a sanding block that has a concave shape, and line it with some foam under the sand paper?
Dec 03, 2021, 11:02 AM
tghsmith's Avatar
with the new info you could cut some sanding blocks to match the curves,, would give a little better control..
Dec 03, 2021, 11:10 AM
Bob Gaito's Avatar
TGH, good thought-I guess cut sections (like an orange) of sandpaper and contact glue them in place?
Dec 03, 2021, 12:06 PM
KC8WPF
CG Bob's Avatar
What is the diameter of the sphere? Cut a PVC pipe coupler in half to make two tunnels or chutes. Glue sandpaper to the inside.
Dec 03, 2021, 12:16 PM
Where's the pond?
patmat2350's Avatar
Right! I was misthinking the process of ball bearing grinding. Here's how it's really done, no application here:
https://science.howstuffworks.com/tr...uestion513.htm
Dec 03, 2021, 12:49 PM
Bob Gaito's Avatar
That could work on this...hmm
Dec 03, 2021, 03:49 PM
Just Plane Nutts
AirDOGGe's Avatar
Might find something useful here: https://www.youtube.com/results?sear...nding+a+sphere
Latest blog entry: My You-Tube channel
Dec 03, 2021, 05:38 PM
pmackenzie's Avatar
Originally Posted by AirDOGGe
Should have done it like this
Explosively hydroforming a steel sphere (0 min 19 sec)
Dec 03, 2021, 05:54 PM
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
If it's alraedy close, Use the guide coat / wet sanding method to evenly block it out.
The real one isn't perfect either. Welded steel or fiberglass on the original?
DH
Dec 03, 2021, 10:17 PM
Bob Gaito's Avatar
Yeah it's welded steel with big gaudy weld seams -hammered, sandblasted and paint... But in 1:24th that all kind of disappears and so it's got to be smooth.
Dec 04, 2021, 02:08 PM
Lost in the Sky
Richard N's Avatar
Make a "C" shaped sanding block from soft balsa and spray glue or double sided tape sandpaper to it. You can get a spherical curvature inside of it by putting a strip of sandpaper on your sphere and sanding the shape into the block.
Discussion Hobby King Sand Storm spare parts - or new RC to use Sand storm electrics? ipjodan Off-Road Vehicles 3 May 27, 2016 09:28 PM
Discussion Half sphere helix/helical, how to or specs? DiluxEdition FPV Equipment 7 Feb 14, 2016 09:19 PM
Discussion Have they found a Dyson sphere? dll932 Life, The Universe, and Politics 29 Nov 07, 2015 11:16 AM
