This thread is privately moderated by Stone1295, who may elect to delete unwanted replies.
Dec 01, 2021, 07:16 PM
Trader Rating: 123
AMA 937634
Stone1295's Avatar
$60.00 USD
Buyer pays shipping
For Sale
Bernoulli 3515 Brushless Drone Motor with Integrated ESC and LED Nav Light
I have two of these and they are $60 each but if you purchase both I'll price them at $50 each.
These motors are produced by Inspired Flight, a drone company which makes higher end work drones. In the past they offered these motors separately but it looks as though they aren't on their website any longer. www.inspiredflight.com
You can still find their announcement on RCGroups for these motors as well as an old Amazon ad.
https://www.rcgroups.com/forums/show...-ESC-Nav-Light
https://www.amazon.com/Bernoulli-Bru.../dp/B0797D6KLY
Here's the text from the Amazon ad:
Powerful 600W Brushless Motor with Integrated ESC and LED Nav Light.
The Bernoulli 3515 is the only fully integrated drone motor on the market. No soldering or programming required - Simply Plug n' Fly
Lift a huge array of payloads with each motor capable of lifting 1.5 Kgs, making it possible for a quadcopter to lift custom payloads up to 6 Kgs.
It's never been easier to build your own custom drone with the high-performance and reliability of the Bernoulli 3515, the only plug n' fly solution available to DIY drone enthusiasts.
Don't limit yourself to what an out-of-the-box drone can do; possibilities are endless with the Bernoulli 3515 integrated motor.
Shave hours off your build process with this 3-in-1 motor solution from Inspired Flight.
The Bernoulli 3515 comes with integrated ESC and RGB Nav-Lighting, creating one of the most powerful and intuitive drone motors on the market.
With the built-in direction switch, customizable LED and XT30 connector, no soldering or programming is required. Simply Plug-in and get flying fast!
SPECIFICATIONS:
Motor Size: 3515;
Weight: 167g;
kV: 500;
Shaft Size: 4 mm;
ESC Voltage Range: 10V - 25.5V;
Battery: 3s - 6s LIPO;
Max Operating Current: 32 Amps;
Mounting Bolt Pattern: 16x19, 19x25, & 25x25;
Recommended Prop: Multirotor: 12-inch to 15-inch Diameter, 3-inch to 5-inch pitch Fixed Wing: 10-inch to 13-inch Diameter, 5-inch to 9-inch pitch;
Recommended Aircraft Weight: Multirotor: Up to 1.5 KG (3.3 lbs) per motor Fixed Wing: Up to 4 KG (8.8 lbs) per motor.
WHAT'S IN THE BOX: Bernoulli 3515 Integrated Motor Prop Adapters: 6 mm Threaded Post and T-Style 50 cm Long Pre-Soldered Power Cable w/ XT30 30 cm, 50 cm, or 75 cm long Signal Cable (specify above) Mounting Screws
I have two of the motors that are brand new. Never mounted or spun up.
Thanks.
-Mike
New Product Bernoulli 3515 Brushless Motor - Integrated ESC and Nav Light MarcRacer18 Scratchbuilt Multirotor Drones 6 Mar 22, 2018 08:36 AM
Article Contest! - Bernoulli 3515 Integrated Motors Jim T. Multirotor Drone Talk 96 Mar 08, 2018 07:11 AM
New Product Bernoulli 3515 Motor - Integrated ESC & Nav Light MarcRacer18 Electric Power Systems 4 Feb 16, 2018 02:22 AM
New Product Bernoulli 3515 Brushless Motor - Integrated ESC and Nav Light MarcRacer18 Multirotor Drone Talk 0 Feb 15, 2018 05:19 PM
