This thread is privately moderated by rtl, who may elect to delete unwanted replies.
Nov 29, 2021, 04:46 PM
rtl
rtl
Your first workshop
Like anything else, learning what’s involved in a new hobby is the first step to taking it on. From figuring out what tools you’ll need, finding a place to store essentials and creating an organized place to work and play, it’s always important to do some preparation. That is especially true for aviation modeling.
Aviation modeling is a lot more than kits and parts. Before you even open your first kit, you need a dedicated space where “the magic happens.” Having a prepped location ready for your first build will make the whole process much easier (and a lot more fun) so that’s why we’re sharing these tips.
Let’s get started!
Dedicated Location
First off, you’ll enjoy your build more if you have a dedicated space. You need the freedom to spread out and stay organized. It will make a big difference when you don’t have to clean up in the middle of your project (or worry about the family pup getting into your small-parts pile).
If you have a spare room you have the perfect space and an old table is all you really need. You can also use plywood and sawhorses if they are sturdy. Once you find the perfect spot with a solid and flat work surface, you’re ready to start adding tools.
Building Boards
Few modelers build directly on their work table. They often use “building boards” with a cork top surface. These soft-top building boards allow modeling pins to be pushed into their surface so you can hold all the parts of a build kit safely in place.
ProTip: You can use insulation foam boards and ceiling tiles too! Just use a spray adhesive to attach it to the top of your workbench and keep it from moving.
You won't want to cut things on your building board due to the soft surface so leave yourself enough room on your table to have a clear hard surface that can double as a cutting and work area.
Organization
Organize all your hardware to make it easy to find. With so many moving parts, it’s important that everything has a designated location as you progress through a project.
Lighting
With so many small pieces of hardware and minute details to get right, make sure you have ideal lighting in your work area. Optimally, you should have overhead lighting as well as a moveable spot or task light that allows you to direct the lighting exactly where you need it.
Basic Tools
The old saying that “you can do anything with the right tools” is particularly true in modeling; the proper tools will simplify any job. Whether it’s a quick-assembly ARF or a complete scratch-build, there are basic hand tools that every modeler needs.
Any modeling project can be completed with a simple workshop as described above. Once you have your workshop situated, it’ll be time to select your first kit or ARF (Almost Ready to Fly) and get started, knowing that you already have everything you need!
Jan 01, 2022, 01:37 AM
Ah! A new building board! We have just moved house and downsized and during the move my old building board was "lost" in the shipping. What experience have people had (if any) using insulation foam boards with cork facing applied? I have attempted to use "laminex" with cork floor tiles however it seems impossible to apply them without slight gaps and an uneven final surface. Here in Australia it is possible to buy lengths of 6mm cork which could be fixed to the foam board with the suggested contact adhesive. Oh for the old fashioned fibre board.
Discussion Move Static Wood Models to your Workshop DW Hobby The Builders Workshop 2 Dec 22, 2017 03:58 AM
Discussion What does your hobby room/workshop look like? beenflying Electric Heli Talk 26 Nov 06, 2017 04:00 AM
Discussion Your workshop need a Tool Box & Holder,come to get it ! DW Hobby The Builders Workshop 7 Jul 25, 2017 04:32 PM
Gallery Post pictures of your RC workshop. Post and swap ideas for workshop upgrades. jhebbel The Builders Workshop 85 Jul 31, 2016 10:16 AM
Discussion Building a Workshop - What is one thing you can't do without in your workshop? Salter Foamies (Kits) 8 Sep 08, 2014 08:59 PM
