This thread is privately moderated by kopterheld, who may elect to delete unwanted replies.
Nov 28, 2021, 06:29 PM
Mini-Review
HappyModel ES24TX Pro 1000mW ExpressLRS 2,4GHz Module
The ExpressLRS 2G4 transmitter module ES24TX happy model up to 1000mW, fan, RGB LED and Moxon antenna. Super reception better than TBS Tracer. Range over 30km with 100mW and EP1 receiver.
Happymodel ES24TX Pro Version:
BG Code: PARTS8 - https://www.banggood.com/custlink/D3DhbGFmTA
AE - https://s.click.aliexpress.com/e/_AeLqQf
Happymodel ES24TX (250mW)
AE - https://s.click.aliexpress.com/e/_Arc4Yx
BG - https://www.banggood.com/custlink/G3GhLFYp81
Video (EN subtitle) -
HappyModel ES24TX Pro 1000mW ExpressLRS 2,4GHz Modul (3 min 55 sec)
Starter Set ES24TX
AE - https://s.click.aliexpress.com/e/_ANT9cB
Moxon Antenna
AE - https://s.click.aliexpress.com/e/_A1BSGL
Cooling Fan
AE - https://s.click.aliexpress.com/e/_Ag931F
BetaFPV ELRS TX Module
Code: KOPTERHELD21BF - https://bit.ly/BFELRS24G
Inside a thick aluminum heat sink with fan
There are no electrical components on the heat sink side.
On the lower side you can find everything - even a Bluetooth antenna where, from ExpressLRS 2.0 onwards, you can use the wireless joystick on the PC flight simulator
Behind the fan there is an RGB LED that can be used as a status LED from ExpressLRS 2.0.
The 3 modules from Happymodel - the slim version on the left, the standard with 250mW in the middle and the pro version on the right
the slim version has a telemetry bug and needs to be repaired (SMD soldering)
The housing of the large Happymodel module is too slim and the spring arms have to be bent apart so that the module does not fall out of the radio like TBS Mambo, Radiomaster TX16S, Eachine TX16S.
ExpressLRS Configurator - https://www.expresslrs.org/
Kopterheld Coupons:
https://t.me/s/KopterHeld
https://kopterheld.tv/
My equipment:
DJI FPV Goggles V2 - https://www.banggood.com/custlink/DDmRIkhAdY
Fatshark Dominator HDO2 - https://www.banggood.com/custlink/KmGKeeY4pN
ImmersionRC RapidFIRE - https://www.banggood.com/custlink/vm3v6vafP1
Radiomaster TX16S - https://www.banggood.com/custlink/vGvKMV73QP
CADDX Ratel 2 - https://www.banggood.com/custlink/GDvEFB6wnC
Youtube https://www.youtube.com/kopterheld
Blog https://kopterheld.tv/
Instagram - https://instagram.com/kopterheld
Twitter - https://twitter.com/kopterheld
Discussion Happymodel ExpressLRS F4 5A 5-in-1 AIO FC w/ Built-in 2.4GHz Rx Fidy$Trainer Micro Multirotor Drones 3 Aug 31, 2021 02:10 AM
New Product ExpressLRS ES915TX ES24TX (915mhz / 2.4ghz): Radio revolution for tiny ? MultirotorDrones Micro Multirotor Drones 9 Apr 14, 2021 04:11 AM
