Nov 25, 2021, 07:27 PM
Cougar429's Avatar
Help!
Glow Driver Setting
One of these two cylinder glow drivers arrived today and there is some info on specs, but nothing on how to set it up, such as programming a second channel to turn it on:
https://hobbyking.com/en_us/two-cyli...ug-driver.html
Anyone have any experience with it? Plan to install it on the Gemini 160 to help idle.
Nov 26, 2021, 07:56 AM
ƃuᴉʇɐǝʞ ʇʇoɔs
vulturetec's Avatar
From the documentation from HK's website:
The device is shut off when the control signal pulse width is less than 1.4ms; when the pulse width is between 1.4ms and 1.6ms,it is on stabilizing mode; when the pulse width is more than 1.6ms, the device is on start mode. Normally, we can identify one idle two-gear or three-gear switch on the transmitter to control the device. After the device enters Start Mode for 30 seconds, it enters Stabilizing Mode automatically, under which it won’t be lasted 5 minutes of working time, afterwards, it will be on shut off state, it can be triggered again and time counting will be restart, in this case, customer don’t need to worry that sometimes they forget to put the switch to“off”position, no need to worry that the device will exhaust the receiver battery.
If your radio doesn't show what it's transmitting in ms, your control channel would be set for "stabilizing" mode at 50% throw, starting mode at 100% throw, and off and 0%.
Nov 29, 2021, 07:12 PM
Cougar429's Avatar
Thanks. Already have that file printed out.
Checked it plugged into the Rx and battery source, but only had one function change, from fast flash to slow, with no Sonalert. Can only think with no glow plugs connected it may not fully function.
Nov 29, 2021, 07:14 PM
Cougar429's Avatar
Double post
Discussion On Board Glow Drivers. Discussion Q&A SlickZERO Engines 65 Oct 10, 2019 01:55 AM
Discussion HobbyKing Smart Glow Driver V2 RCD3007E XRAYRON Fuel Plane Talk 5 Jan 22, 2016 12:15 AM
Discussion glow plug driver wood Fuel Plane Talk 23 Oct 04, 2015 08:01 AM
Question Advanced Glow Switch/On Board glow driver deckert Fuel Plane Talk 4 Jul 20, 2010 03:05 PM
Discussion pro glows Up graded SC SR105 on board Glow plug driver psjdb Fuel Warbirds 0 Jan 17, 2009 08:37 AM
