Choosing motors for a twin
Is there a general rule of thumb when choosing motors for a twin?
I've kinda gotten the hang of choosing a motor for a single. What baffles me is how to factor-in the second motor. The only factor that comes to mind is a twin has a second prop wash over the wing. I'm certain there are other factors, but have no idea what they are and what to do about them. Hoping for some guidance! |
Unless you like to fly in circles, I would recommend two fairly close matching motors systems, unless you are talkig about an inline pair, (push-me-pull-you_).
That's funny!
My goal is to properly size twin motors for a given airframe. Example: (I'm making this up) - Piper Comanche vs Twin Comanche - 65" wing - 750 in2 wing area - 9 lbs auw - 28 oz/ft2 wing loading - single motor is a Power 60 Is there a rule of thumb to go from that single motor to a twin setup on the same airframe? |
I've always thought that it made sense to split the power as well. Especially with electric motors where it's still the total watts per lb provided. One factor I think is important would be the Kv values of the motors. I feel that having a similar total prop disc area for moving the air is going to be needed to keep the climb for the power used similar. So we can't replace a big slow turning prop that has a good bite with a couple of small high RPM toothpicks. That's certainly going to affect the climb rate if things are way out of whack.
Thread Tools | |
Similar Threads | |||||
Discussion | Can we move on from choo choo trains now? | plowboy1966 | Life, The Universe, and Politics | 29 | Feb 13, 2018 03:22 AM |
Discussion | Futaba 10J programming for twin motor / twin rudder | Spellbound714 | Dock Talk | 2 | Jul 03, 2016 11:20 PM |
Discussion | Looking for: FPV Twin motor H-Tail | Hayden88 | FPV Aircraft | 1 | Apr 02, 2016 10:24 AM |
Discussion | Completed Project Choo...Choo... | freddy warbird | Life, The Universe, and Politics | 9 | Mar 27, 2011 04:00 PM |
