Nov 17, 2021, 09:35 AM
F3B and F3K
RetoF3X's Avatar
Yoda EL
Seen on rc-network.de, an electric Yoda F5K model.
Four servo, two piece wing, with some nice engineering on the flap servo install. The flap servo pocket is similar to the solution in the Flitz 3 F3K model (https://www.rcgroups.com/forums/show...17&postcount=3 ), or some of the Jaro Mueller models (Egida, Espadita, etc).
Also a wing-fuselage joint like on the bigger F3B/F5J models.
I am myself not interested in F5K, but I appreciate the evolution of models in that class, and the engineering details.
Best,
Reto
Image source: https://www.rc-network.de/threads/yo...#post-12144036
Latest blog entry: thoughts on contest flying
Nov 18, 2021, 01:05 AM
Thermal Wrangler
DrFragnasty's Avatar
Thanks for sharing Reto.
Who's going to be the first to fly it in an F5J comp. and embarrass the 4m ships?
Nov 18, 2021, 07:36 AM
In F3J size does matter!
roydor's Avatar
Not saying it can’t be done but F5J ships have about nearly 50% better performance than F3K models in L/D and sink rate.
On span alone they can go 250% further downwind (visibility)
The only advantage an F3K model has is its ability to turn same radius with less speed difference between the wing tips…
I have had this discussion a few times in the past and unless it’s a very low wind day with lots of thermals, making 10 minute flights from 30 meters with a 1.5 meter model on each one of your official flights is harder than you think…
Nov 18, 2021, 09:15 AM
Mark LSF # 3792
Reto, thanks for showing this to us. I too am not interested in that new class, but like seeing the new technology.
roydor, I have a Horejsi Geronimo that I bought to fun fly. I was asked why I have not flown in our local F5J annual event. What you describe is exactly the reason I won't. Asked the inquirer why should I handicap myself before I start with equipment that can't compete in our normal conditions? Besides, I told him, "I'm handicapped enough". BTW, the Geronimo is a fun little airplane to fly and performs very well for it's size.
Nov 18, 2021, 03:15 PM
Not landing late ever again
threcixty's Avatar
How does it do on a 5s and a half kg of ballast?
Nov 19, 2021, 12:05 PM
Aaro's Avatar
It is of course a fascinating idea to "show them" with such a nice, probably less expensive little glider. We have had these in our F5J-competitions, flown by rather good pilots. In the end, they land out or to trees, or never get up again after the first bubble is lost. My conclusion is that F5K-gliders do not generate thermals more than F5J gliders do
Aaro
Nov 19, 2021, 01:38 PM
F3B and F3K
RetoF3X's Avatar
In preparation for the 2011 F3K worlds, I did AULD with my buddy Neal Huffman launching his light Supra on a bungee while I threw my SalPeter or Steigeisen.
The results were very clear: to range out to a distant thermal, the legs of the Supra were shockingly better than those of an F3K plane. In a small, weak thermal, the F3K plane could sometimes hang on to something the J plane couldn't.
Years later repeated some flights with Daryl Perkins flying his J planes. There was still a small edge of the SALpeter for tiny, weak thermals, but on anything else, the J plane was much more performant.
F5J planes might now be even better in weak thermals than the J planes back then, and the large advantage in legs should still be there.
But back to the plane in this thread!
Best,
Reto
Nov 20, 2021, 10:52 AM
Tuomo's Avatar
In a weak thermal it is a night and day difference between 2011 F3J plane and 2021 F5J plane.
Nov 22, 2021, 10:21 AM
F3B and F3K
RetoF3X's Avatar
Back to topic:
there are some pictures on Darius Mahmoudi's website.
https://mahmoudi-modellsport.eu/yodael
In particular, this insert holds the servos and ballast, and has the wing connectors integrated.
I like that idea and might do something similar for a much larger F3G plane.
Best,
Reto
Nov 23, 2021, 12:21 AM
Shouldn't this plane be called a Yodel?
Question ¿Dónde venden el Epp, el Depron o el Foam? Místico Mexico 1 Jan 23, 2008 02:39 PM
