Sky Flieger - AMA Free Plans
Build this easy-flying, three-channel airplane As seen in the October 2021 issue of Model Aviation.
Sky Flieger Build Plans and Info
Written by Clark Salisbury...
This airplane project has been one of the most fun that I have ever completed. I was looking through my covering material and discovered that I had a lot of yellow, red, and black. It hit me that those are the colors of the German flag.
This airplane uses the wing from a design I created six years ago called the SkyEye, but I wanted this model to be able to carry at least one pilot and a Barbie-size passenger.
It has a lot of dihedral that makes it easy to control with three channels. Rudder-only turns are beautiful. The wing loading is low and that translates to fast takeoffs from grass, even at half throttle. I also wanted to have plenty of lighting on the airplane for flying at dusk, so I used 22 white LEDs. My plans show you where to install them. Well, letís get into building.
Materials Needed
  • (6) 3/32 x 4 x 36 balsa sheets
  • (12) 3/16 x 2 x 36 balsa sheets
  • (6) 1 x 2 x 12 balsa blocks
  • (1) 1/4 x 1/4 x 36 balsa strip
  • (4) 3/8 diameter x 36 wood dowels
  • (3) 5/16 diameter x 36 wood dowels
  • (8) 1/2 x 4 x 12 balsa blocks
  • (1) sheet of 1/8 aircraft or poplar plywood 12 x 24
  • (1) sheet of 3/16 poplar or aircraft plywood 12 x 24
  • (4) rolls of covering material, three colors plus clear for the windows
  • (2) Sullivan 5 x 1.75 wheels No. S883 or 4.75-inch diameter foam Multiplex FunCub wheels
  • (1) 12-inch #4-40 threaded rod
  • (1) package Du-Bro standard hinge (DUB116)
  • (4) Du-Bro ball links with hardware #4-40 (DUB2161)
  • (1) Du-Bro control horn (DUB237)
  • (1) package with a formed windshield, landing gear, and instrument panel gauges (available from the author)
  • (2) #8-32 x 2 machine screws
  • (4) #8-32 hex nuts
  • (4) #8-32 nylock nuts
  • (10) #8-32 nylon pan head x 1-inch screws
  • (10) #6-32 nylon pan head x 3/4-inch screws
  • (2) 1/16 diameter x 12-inch steel rods
Specifications
  • Wingspan: 71 inches
  • Length: 57 inches
  • Height: 21 inches
  • Weight: 4.5-plus pounds
Test-Model Details
  • Motor used: E-flite
  • Power 25 or equivalent
  • 1,250 Kv brushless outrunner
  • ESC: E-flite or equivalent 40-amp
  • Battery: 3S 2,100 mAh LiPo battery
  • Radio system: Fourchannel radio and receiver
  • Servos: Hitec HS-85BB
  • Propeller: Electric 11 ◊ 5.5
Get the Free Plans
Head over to the AMA website for the free downloads and much more build info.
Nov 15, 2021, 05:44 PM
Right Rudder
PittSpecial's Avatar
Nice! Look forward in more posts on t his project.
Nov 16, 2021, 02:41 AM
jgg12002's Avatar
Looks like a great after dinner plane to just buzz around and enjoy the beauty of flight.
Very nice entry.
John
Nov 16, 2021, 07:37 AM
Onward and Upward.
CatManDu's Avatar
This is cool. Promoting airplanes you have to build. Nice. Keep up the good work. Thanks.
Randy
Nov 16, 2021, 12:37 PM
With those colors, a good name woulda been Der Flugenscooter
Nov 16, 2021, 03:59 PM
I wish she was a true successor of this nice hobby, if not not sure why they took that photo with her in
Nov 16, 2021, 07:39 PM
Right Rudder
The girls matching clothes next to the model looks just amazing!
The more I see this model, the more I want one!
I need to clear off a space to build!
Pitts
Nov 17, 2021, 05:00 PM
For it's weight it seems more suited to a 4s lipo.
Nov 25, 2021, 09:51 AM
Lokai's Avatar
Beyond my skill level, but I'm glad others enjoy it.
Nov 29, 2021, 10:07 AM
Sagitta Fanboy
3s on that motor is just fine for 75-100W/lb, which is all a 3ch trainer needs.
You're talking 350-450W
Build Log Pluto TD retro RC1 style free download plan Thomas B. Foamies (Scratchbuilt) 7 Apr 04, 2016 01:18 PM
Discussion Free download plan: "Holz Raus!" - an electric balsa-glider, 1,5 m wingspan Hilmar Electric Sailplanes 0 Nov 20, 2015 01:38 PM
