Apr 29, 2002, 07:21 PM
Got $1 for materials?
Okay, so you probably have all this stuff laying around and it won't cost you anything, that's OK too. Mostly it's 3/8 to 3/4 thick styrofoam (thickness doesn't matter much) cut it out with whatever's handy and if you want to get fancy you can sand the leading and trailing edges (flies OK with or without). 24 inch span, 24 inch long, DXA drive, 9x7 to 11x8, 2 or 3 servo's,2A esc, GWS rcvr and 6 to 8 cells. 3 channel with low throws on 6 or 7 cells and a 10x4.7 it flies like a trainer, add rudder for ROG's. 4 channel with the throws maxed out on 8 cells and a 9x7 it gets pretty exciting, that's why I call it the Heart Attack. Have fun!
Apr 30, 2002, 12:25 PM
Formerly of mcba fame
Matthew Allen's Avatar
Cool
What batteries are you using?
What duration are you getting?
Weight?
Apr 30, 2002, 12:43 PM
Current draw's about 2A. I've flown it on everything from 120 to 720 nimh, durations 3 to 15 minutes depending on the pack and how much you bang it around. AUW's around 6 oz depending on the pack.
Apr 30, 2002, 04:04 PM
would an IPS work ? i dont think it would be enough
Jeff
May 01, 2002, 04:58 AM
The DX-A is a version of the IPS.
CAn it do anything like a hover?
May 01, 2002, 08:09 AM
Experimented with the larger GWS props (11,12,14 inch). The thrust is there with the 12 if I remember right, and I've had it hanging momentarily. I think if I played with the vertical cg and I was 20 years younger I could probably hold it in. It's such a blast messing with the other stuff it can do (vertical landings, the "Wall" (high speed 180 turn in a fuselage length), outside loops and a bunch of stuff I can't describe) that I haven't spent a lot of time concentrating on a hover.
May 02, 2002, 04:05 AM
soft yummy goodness.
freq's Avatar
Coolness, Mike. Heck, you could even call it a "gift" to your wife. Reminds me of a Mini IFO, and some of Dan Kreigh's tricks to keep it light would probably work.
I've been loving the DX-A, 10x4.7 prop, and 8x300 NiMH on the mIFO.
What's the weight without battery? For reference, my mIFO is a hair over 3oz and goes way beyond hover with above setup.
You could try a one-wheel CF/wire landing gear in the front with 2 CF skids in the back, ala mIFO, to shave a few grams. OK, now we're up to $2.50. Sell your spinner for $.50 to save money & weight, back down to $2.
Elevons + rudder must be really interesting.
-chris
May 02, 2002, 08:29 AM
Actually I got the idea based on my IFO and Mike Banke's "Son of Tuit"and sprinkled in some of my own experience. The IFO is easy to lose orientation with and hard to repair. This things red on top and white on the bottom so it's easy to see and if you crack it up Elmers fixes it right up. You can see some of the repairs in the picture. Weights 5 to 7 oz depending on the pack. First flight was on Valentines day a year ago, women get a real kick out of it. The idea with this thing was to keep it super simple, cheap, easy to repair and capable of doing pretty much anything, hence the title of the post "Got $1". That's about what the materials cost. Hope I didn't give anyone the impression I was trying to sell something here.
May 02, 2002, 11:38 AM
freq's Avatar
Funny, I thought I had seen a similar size heart around here before and wondered if it might be yours. Guess that was you!
So I figure you're around 4oz without the pack? Great weight without any fancy stuff.
The design is great: cheap, easy build, easy fix. Lately, I've been having a hard time breaking my mIFO. If you saw the way I fly it, you'd swear I was trying to kill it.
BTW, I did get the joke... just hope I didn't throw people off with my extra $1.
Oh, and I love the name.
-chris
May 02, 2002, 05:21 PM
Strange Plane Central
frankenfoamy's Avatar
something similar
http://rcguy.tripod.com/valentinecupid.htm
May 03, 2002, 07:44 AM
Cool. Basic shape works so well I'm not surprised to see it's been used before (well, not really, a lot of the guys I know wouldn't be caught dead with one of these) too bad, their loss.
May 03, 2002, 04:16 PM
Tee Sqaured
Thomas Manson's Avatar
Hey, i can make 361 of those nice looking litel plane
Fly man
May 04, 2002, 12:31 PM
Anyone want to bet me I can make one in 2 hours...right after i get the foam and ride my dirtbike of course?
May 06, 2002, 08:54 AM
Should be able to do it in less than 1 hour. The only piece of wood you need is the motor mount/LG support. And the only reinforcement is a piece of reinforced packing tape that runs full width across the back and doubles as the elevon hinge. Took me more time to make it red than anything else. Gotta get an air brush.
May 06, 2002, 03:03 PM
Master ReKitter
uglyplane's Avatar
I have coroplast on hand, would that work or would that be too heavy?
Discussion E-Flight Yak 54F , anybody got 1 ??? Jiffy 3D Flying 0 Oct 16, 2006 05:39 AM
Has anyone got a 1/12 scale Spitfire instrument panel? YEAP CHIN POH Scale Kit/Scratch Built 7 Mar 24, 2005 09:27 PM
I WANT ONE OF THOSE, got 1 4 sale? R6JIMBOB Motorcycles 1 Aug 23, 2004 10:43 AM
