Nov 07, 2021, 02:44 PM
Question
Setting up multi-engine with a A9
How would you set up 2 GAS/GLOW engines on a Cessna Skymaster with a Hitec A9?
Bob
Dec 29, 2021, 08:41 AM
Easy use 2 ESC and y connector on power leads to battery. I'm sure you can do coupling with another motor esc channel in the channel settings and tie it to left stick throttle. Now if you are talking about differential thrust that is a whole different story.
https://www.rcuniverse.com/forum/hit...ml#post9822646
PS
You can setup dual engine during the setup
Aurora 9 Basic Setup Video (7 min 8 sec)
Dec 29, 2021, 11:07 AM
OOOOPPPSS I should of mention GAS/GLOW engines.
Your info was interesting.
Discussion Aurora: Trainer / Buddy system Master & Slave function Set-up & Data Transfer A9<>A9. A.T. Hitec/Multiplex USA 70 Jun 15, 2018 11:03 AM
Mini-HowTo Tips for setting up Multi-"Engined" Electrics JetMang Electric Warbirds 4 May 14, 2016 06:37 PM
Discussion Glider set up: updated A9 software Woodstock 1 Hitec/Multiplex USA 6 Mar 16, 2012 10:27 AM
Discussion Multi engine set up. Cosmo21 Electric Ducted Fan Jet Talk 6 Jan 31, 2012 03:45 PM
Help! Another Multi Engine Set-up Foamenator Scale Kit/Scratch Built 2 Mar 27, 2009 03:24 PM
