Futaba - SBC-1 S.Bus Channel Programmer
Whether you are trying to cut down on your model’s weight or wanting to simplify the wiring in your model our new U series SBUS servos are an excellent option to do so at an awesome price
One common question we get is “How do I change the channel in the servo on my older transmitter?” While you may not be able to change it on some of the older transmitters, we have a few answers for that from either using our CIU-3 and our GPB-1, however, the quickest and easiest way is the SBC-1 which you can do out at the field or in your home with ease and no computers necessary.
With the SBC-1 you can plug your servo directly into it and set your channel with the twist of a dial and a push of a button your channel will be set. This small programmer fits perfectly in any hobbyist toolbox and coming in at $29.99 it’s a no-brainer to have for your next project!
Links
Question When using a the S-Bus "channel" what can I use the other channels for?! neavissa Radios 20 Feb 23, 2017 05:42 AM
Discussion Futaba R2008SB S.Bus 8-Channel S-FHSS Receiver stratoblaster Radios 2 Mar 20, 2016 03:20 PM
Discussion Pixhawk, X8R S-BUS, channels 1-8 kenjancef Multirotor Drone Electronics 9 Feb 23, 2016 09:00 AM
Discussion *Futaba R2008SB S.Bus 8-Channel S-FHSS Receiver* olezippi Radios 10 Jan 24, 2016 03:58 AM
New Product S.BUS Decoders and Programmers from HobbyKing bwoollia Radios 0 Jun 14, 2012 11:45 AM
