Nov 01, 2021, 07:56 PM
Trouble shooting Hitec Servo
Greetings. I'm trying to help out a friend. He has a mechanical device that has a moving part controlled by a megaquarter scale Hitec HS-805MG servo and a Servocity 4 channel servo recorder. The controller just uses one channel.
Its not working. it was connected to a 12V supply by mistake and we are not sure which bit or bits are dead. I don't have another controller but I have some experience with arduino devices and i was wondering if this servo can be controlled with an arduino. If someone has code that would be amazing. I'm starting to cobble together something that operates little servo's with a hope that it might work.
When I connected 6V to the servo it ran smoothly and appears to have gone back to a zero position. I'm hoping its ok. However when we connect it to the servo controller with 6V things seems to get hot at the controller end.
I've looked at the output of the controller on my oscilloscope and it generates a signal but its not a square wave as I expected.
I was wondering if one of the smart and clever folks here might be able to point me in a direction that could resolve this issue.
My gut feeling is that the servo could be working but the controller has departed this world.
I'm also wondering what the device is at the back of the large cog. It has three wires going into it. I'm assuming that its some sort of feedback device that tells the servo where it is. However i'll be guided by folks here.
I've attached a few pictures of the device.
Thanks in anticipation.
Peter
Dec 20, 2021, 09:18 PM
You have most likely toasted the servo electronics with 12 volts.
That servo series is not even rated for operation on 2 cell lipos 8.4 volts.
Run them on 6 volts 5 NiCad / NIMH and they will last forever.
The three wires are either going to the motor or the feedback / position pot.
Help! If this was yours, what would your next step be? Trouble shooting Hover01 Beginner Multirotor Drones 12 Apr 13, 2016 06:47 PM
Discussion Ultimate2 Trouble Shooting Suggestions pedalmasher Electric Plane Talk 9 Mar 06, 2016 12:28 PM
Help! Asking for forum help in trouble shooting customers problem. frankg Scale Boats 23 Dec 14, 2015 03:55 PM
Help! 350 QX3 Trouble Shooting (altitude) jsreimer Multirotor Drone Talk 4 Sep 28, 2015 10:49 PM
Hitec 555 Rx Trouble shoot Wolfman Radios 5 Dec 22, 2004 04:21 PM
