Oct 21, 2021, 10:28 AM
Help!
Coroplast hinge issue
I have a plane built from Coroplast. the rudder and elevator use the method of cutting one side of the coroplast to make a hinge from the remaining side. It's rather stiff. Anyone have a proven solution that you have used? I could drill holes or cut some slots in the hinge side to make it flex easier. Tell me what you have done to ease the problem.
Oct 21, 2021, 12:17 PM
William A's Avatar
Cut it off completely (save the tab) and use tape for hinge.
Oct 21, 2021, 09:56 PM
Coroplast hinge
This is a 40 size SPAD. What tape would you recommend that would be strong enough and hold up to glow fuel?
thanks for your suggestion.
Oct 22, 2021, 02:53 AM
PROPJET- you can use normal model hinges. I did it with my Skyboy. I cut the transverse structure of the coroplast with a knife, apply some foaming glue inside, insert the hinge, and to be sure, add a stapler. You can see in the photo - both this is the case for ailerons and horizontal stab.
Nov 02, 2021, 03:57 PM
Call me Frosty
TheRealFrosty's Avatar
This is from the spadtothebone site. (which currently seems to be offline)
Nov 24, 2021, 10:01 AM
I have used the third method on a 1/2A plane, but like method #2. Might try that some time. http://www.frostracing.com/spadtothebone.org/plans.html I have this in favourites. Seems to work. I am sure The Real Frosty is more informed than I.
Nov 24, 2021, 04:20 PM
Call me Frosty
your link is to my backup of the files in case the site goes down again. the real site is being hosted for free (in a agreement between the owner of spadworld.net and a member over there) at www.spadtothebone.org/plans.html.
but either link should work.
Discussion depron /tape hinge issues highflier Foamies (Scratchbuilt) 14 Apr 28, 2021 03:33 AM
Discussion Ca hinge issues highnpressurized The Builders Workshop 31 Aug 15, 2013 10:24 PM
Discussion Flickenstein 40% AS-W 15B rudder hinge issue aeroanalysis Scale Sailplanes 24 Jun 25, 2011 04:22 AM
Discussion Issue with Stryker Hinges jpwkeeper Flying Wings 4 Oct 15, 2009 11:58 AM
Discussion live hinges kevlar/fibre glass issues? soarluck Composites Fabrication 3 Aug 14, 2009 12:41 PM
