Oct 21, 2021, 02:05 AM
Hirobo Paraplane Sport
Hi @all,
i found the Wing of an Hirobo Paraplane Sport.
But itīs only the Wing...
My Idea is to bring him "Back to Life"....
So i start to create a new Trike for it.
The Main Difference to my other Paramotor is, that he donīt have this "Brake Lines".
The Control works by a Tilt-Bar.
Luckily i find some Pictures and Details in the Internet, and i have a good Base to start....
What i use at the Moment is following:
3s 2.200 mAh Battery
Roxxy 2827-26 BL-Motor
8 x 4,3 SF-Prop
25A Hobbywing ESC
1 Emax Servo ES 3005 (MG , 42Gr. , 12Kg)
I measure the Motor on my Test-Bed and he provides 662 Gramm Thrust at 14A and 11,7 V
I hope thatīs enough....
Main Issue is, that the Prop is limited to 8" Diameter, because i could not Print a bigger Prop-Ring.
The Tilt-Bar is a 4mm Cfk-Tube that should be strong enough.
Then i start to create the Trike for it.
All Parts are print in PETG, but not the Pilot. Heīs made from LW-PLA.
The total Weight of the Trike, incl. Battery, is 722 Gramm.
When I hold it at the Lines of the Wing, and do right and left, it seems that the Servo has no Problem with the Load.
Just wait for nice Weather and letīs try
Best Regards, Juergen
Oct 21, 2021, 10:02 PM
britinoz's Avatar
That is a great looking project ...... but you may want to think about something a little more rigid for the prop guard...because they can take a bit of bashing. something like a wire clothes hanger, comes to mind.
Happy Landings
Chris...
Oct 22, 2021, 09:24 AM
Hi Chris,
Yes, you are right.
Maybe the Propguard is a bit weak...
I hope that he is the "intended breaking Point" in the Frame (translated by Google...Sollbruchstelle )
The Propguard is easy to replace and when he breaks, i think/hope that he takes most kinetic Energy from the Frame...
Thatīs the Idea, but absolutely not sure if it works
Best Regards,
Juergen
Oct 22, 2021, 06:55 PM
britinoz's Avatar
I had a printed prop guard and it just shattered at the lightest flex...but lets hope you are a little more lucky.
Happy Landings
Chris...
Oct 29, 2021, 03:47 AM
Success...
Hello @all,
Yesterday the Weather was fine. Sunny and a light Wind from South, around 2-3 Bft.
So i decide to Test the Old Hirobo Wing.
What should i say.....Iīm shocked how easy and perfect heīs flying .
Our Grass on the Field is a bit high at the Moment, so i made a Hand-Launch.
A Shame that itīs not on the Video, because it was so funny...
Directly after Start, he goes slowly downward because i donīt have full Throttle in.
After 5 Meters, he made a nice and soft Touchdown with the Trike....I gave full Throttle AND:
He rolls 2 Meters and goes up in the Sky !!!
Absolutely Easy and Uncritical
I had a smile on my Face, from one Ear to the Other !
Then my Colleague was back and took a Short Video from Flying and some Pictures with his Mobile.
The Video is here:
http://www.helimodell.de/trike/Hirobo-Maiden.mp4
I could give some more Way to the Servo of the Tilt-Bar, but only a little (40% actually).
Then the Turns will come a bit better.
Itīs not possible to make Loops or something like that. Not enough Power....
But nice Climbing at Full Throttle and "cruising" at appr. 50%.
Also the Landing was totally easy.
Slowly against the Wind, and he comes down without any Problem.
I hope that i could provide a better Video next Time, that also includes Start and Landing
Best regards,
Juergen
Oct 29, 2021, 08:17 PM
britinoz's Avatar
Congratulations.
Chris...
R/C Hirobo Paraplane? (Have a picture of it) anthonyryan Electric Plane Talk 11 Apr 09, 2017 07:10 AM
Article The Hirobo Paraplane Sport allan Electric Plane Talk 2 Jan 18, 2011 11:28 AM
Hirobo Paraplane nsacco Electric Plane Talk 2 Jan 22, 2004 01:14 PM
The Hirobo Paraplane Sport dave_lilley Site Chat 0 Nov 02, 2001 12:56 AM
