Oct 16, 2021, 09:01 PM
OCD
Wright's Avatar
hollow shaft
Does anyone know of a supplier for 5 to 8mm hollow motor shafts? I have made variable pitch props before with heli tail rotors. This time I want to try a linear push rod through the motor shaft to simplify things.
Oct 17, 2021, 05:34 PM
SDP/SI has 6 and 8mm, though of course expensive like everything else they sell https://shop.sdp-si.com/catalog/?cid=p352
You could always use stainless steel capillary tube, cheap on ebay.
Oct 17, 2021, 10:50 PM
Why wouldn’t you want to use a hollow shaft on any and every motor?
With a locking bushing could you use aluminum? I’ve never heard of an aluminum shaft period.
Oct 17, 2021, 11:33 PM
powercroco's Avatar
We have used a surface hardened shaft and bored it ourselfes.
the the main problem in using a pushrod through a hollow shaft is the friction.
the problem becomes bigger with the lenght of shaft and the rpm of the vpp.
we used small ballbearings into the shaft boring and smaler pushrod.
may be, I can find bck a photo of the old project somewhere on my computer.
with smaller rpm is worked very well.
Oct 18, 2021, 06:13 AM
OCD
Wright's Avatar
Many thanks for the link. I agree with others that friction will be an issue. I doubt I can use bearings but a light weight grease packing with an inner brass push rod could work.
Oct 18, 2021, 03:11 PM
Forgetting a “pushrod” (don’t know
what you’re talking about) and just with a standard outrunner shaft and standard bearings, why not a hollow shaft or an aluminum shaft? Especially with a locking bushing both seem doable, no?
I have a 14mm shaft on a motor size which sometimes I’ll see narrower shafts anyway. The shaft’s strength seems overkill and unnecessarily heavy.
Oct 18, 2021, 08:55 PM
You can probably use a bit of teflon tubing as a bearing. Ball bearings are better for high speed, but at such small diameter it would take a lot of RPM to get the surface speed very high.
Yesterday, 02:04 PM
FLOEY's Avatar
Did a search for Hollow hardened shaft, smallest dia I found here 6mm L=50 price tag $24
https://www.mcmaster.com/hollow-prec...metric/id~2mm/
New Product Skystars 1103 11000KV 1~3S Race Edition Hollow Shaft Brushless Motor For RC Drone FPV Merch Banggood.com 0 Jun 10, 2019 05:44 AM
New Product Racerstar Racing Edition RS PLUS 1407 3600KV hollow shaft/solder pads & RS2205 2300K lmpuIse Multirotor Drone Power Systems 5 Jun 20, 2017 01:47 PM
Discussion Need advice on hollow shaft motors! jonathankrijgsma Multirotor Drone Power Systems 2 Nov 16, 2016 05:13 PM
New Product [$7] Racerstar BR2205S 2300KV & 2600KV - hollow shaft, N40SH magnets, 7075-T10 alloy lmpuIse Multirotor Drone Power Systems 6 Oct 22, 2016 08:51 PM
