This thread is privately moderated by pcrit, who may elect to delete unwanted replies.
Oct 13, 2021, 08:04 AM
Trader Rating: 8
$200.00 USD
Buyer pays shipping
For Sale
Kyosho Rage VE brushless 1/10 4WD Truck RTR
Kyosho Rage VE brushless 1/10 4WD Truck RTR in excellent condition overall with little use. It has only been used 3-4 times. All you need is a battery, I can include one for an additional cost if needed. This is a great truck, sells for almost $300 new, price is firm.
With the RAGE VE KYOSHO brings a 4WD truck for the class 1: 10-off at the start. It could fall back in chassis on the race-proven components of the GP Fazer and devote specifically the redevelopment of the chassis and drive train. It came out a 4WD model is similar to the Lazer ZX-5, but it is much less focused on race but more on Bashing on the doorstep.
The RAGE VE is supplied as ReadySet with the KT-200 2.4GHz FHSS Synchro remote control system. The drive train and all electronics are mounted ready in the model. The body is finished cut, painted and pasted with the decal sheet. Thus emerges the RAGE VE as a sparkling jewel from its packaging.
The chassis made of fiberglass reinforced plastic and forms the basis of the torsion electric off-roader. The trough-like shape and suitably worked webs forces occurring during operation are best introduced into the chassis. Battery and motor sit particularly low in the chassis to achieve an extremely low center of gravity. The receptacle for the battery is so eye specifies that either conventional NiMH stick packs or the much more powerful LiPo Car batteries can be used.
Power transfer in the model via a smooth gimbal system on all four wheels. With a total of 17 ball bearings of the drive train is full ball bearings and extremely smooth. Furthermore, all movable parts are weight-optimized in order to keep the rotating mass in the drive train to a minimum. Thus, the model is very responsive to throttle changes and gives the driver the high agility precise driving feel.
The NEON one engine is perfectly matched to the RAGE VE and delivers uncompromising racing performance "out of the box". Activation is the engine by the Team Orion R10one controller which has a high resolution and ultra-fast response times. On R10one control six-cell NiMH stick packs or 2s LiPo batteries can be connected either. The whole brushless system is designed Waterproof, so include electronics problems in rain or snow the past.
The RAGE VE has front and rear via a differential gear and quality BigBore-oil-pressure shock absorbers with adjustable spring preload out of aluminum. The shock towers are made of 5 mm thick plastic compound, have multiple points of attachment of the damper and survive even tougher enemy contacts without damage. The independent suspension, with classic double-wishbone with adjustable tracks, and a specially adapted to the chassis geometry. Overall, the suspension of the RAGE VE gives perfect traction for superb cornering speeds.
In developing the chassis of course into account experiences from the world champion of models with a KYOSHO. Features like lying steering servo, the perfect chassis balance or very low center of gravity are also reflected in the RAGE-VE chassis and lay the foundation of his outstanding performance!
The shapely body characterized by its aggressive look and highlights the technical demands of this chassis series.
Features
Ready to run ReadySet with KT-200 2.4GHz FHSS Syncro remote control system
WATER PROOF Team Orion Brushless System
Assembled and ready brushless power set
Full ball bearing drivetrain (17 ball bearings)
Permanent all-wheel drive
Light powertrain for reduced moving masses
Extremely low center of gravity
WATERPROOF KS-204WP High-Power
Chassis designed for use NiMH or LiPo batteries
NEONone high - Brushlessmotor
High-resolution, ultra-fast R10one controller (designed for LiPo)
Extremely smooth-running all-wheel-gimbal
Adjustable tie rods to adjust toe and camber
BigBore-oil-pressure shock absorbers with adjustable spring preload aluminum
HiGrip offroad tires on spoke rims
Lightweight, torsionally rigid tub chassis of glass fiber reinforced plastic
Maintenance-friendly design
High Flow Concept Truck Body has original driver figure
Technical data
Scale: 1:10; Length: 395 mm; Width: 280 mm; Height: 140 mm; Wheelbase: 272 mm; Remote control system: Perfex KT-200 2.4GHz FHSS
RC functions
Gas / brake, steering
New Product ZD Racing SC-10 1/10 4WD RTR Brushless Short Course Truck fastmax Off-road Cars 11 Apr 28, 2019 02:47 PM
Sold Kyosho 34253 1/8 Mad Crusher VE EP Brushless Monster Truck 4WD RTR Blue "New In Box" pjwt56 Cars - Trucks and Parts (FS/W) 2 Jul 10, 2018 11:33 AM
Off Site 1/10 Brushless 4WD RTR Stadium Truck $160 San Diego rolis12 Cars - Cars and Parts (FS/W) 0 Feb 21, 2013 05:32 PM
Off Site 1/10 Brushless 4WD RTR Stadium Truck $145 San Diego rolis12 Cars - Trucks and Parts (FS/W) 0 Feb 21, 2013 02:34 PM
For Sale *Reduced* New in box - XTM Rage Brushless RTR 1/18th 4WD Truck Hellsiege Cars - Cars and Parts (FS/W) 2 Sep 02, 2010 08:09 PM
