Oct 11, 2021, 11:49 AM
Asking for a friend
Hitec HSB-9380TH Collar
Hello, the Hitec HSB-9380TH has a silver removable 'collar'. What is its purpose?
thanks
Oct 13, 2021, 02:14 PM
Team AJ Aircraft / Team JR
Xpress..'s Avatar
Used to strengthen the splines on the pictured horn.
Oct 14, 2021, 05:46 AM
Cougar429's Avatar
Without confirming ID a bit confused. Does that encircle the bottom of the horn to prevent the splines from spreading under load?
Personally, if I though that was the case would go with an alloy arm.
Oct 20, 2021, 08:17 AM
Xpress..'s Avatar
Yes. And your thinking is also correct, however certain applications the servo is used in mandate a heavier duty plastic arm. Or some may opt to use the plastic arm for cost savings sake.
Data Hitec HSB-93XX and HSB-94XX series servos information- PAD Xpress.. Hitec/Multiplex USA 2 Apr 02, 2019 05:28 PM
Discussion D-951TW vs HSB-9380TH TBeghtol Hitec/Multiplex USA 1 Mar 20, 2017 11:49 AM
Discussion HITEC D-951TW vs HSB-9380TH TBeghtol Radios 1 Mar 20, 2017 10:48 AM
News Hitec HSB-93XX Series of Servos Paul Onorato Car Talk 0 Jun 21, 2013 06:48 AM
Discussion Hong Kong Self Defense Force HSB Patrol Boat Chris Nicastro Scale Boats 4 Oct 01, 2007 10:31 AM
