This thread is privately moderated by djmoose, who may elect to delete unwanted replies.
Oct 07, 2021, 08:20 PM
djmoose's Avatar
Build Log
20cc Zero Tail Feathers and Tail Codes
After going over Japanese WWII aircraft tail codes, we'll take care of everything in tail...horizontal stab, elevators, rudder, servos, linkages...and finish with the tail wheel.
Install Elevators, Rudder, and servos on the Phoenix Model 20cc 68" Mitsubishi Zero ARF - Tail Codes (10 min 0 sec)
"The tail unit was of all-metal construction except for the rudder and elevators, which were fabric covered. The tail fin formed an integral part with the rear fuselage, while the horizontal tail surfaces were attached just above the fuselage centerline.
Each elevator had a metal trim tab that could be controlled by the pilot, but the rudder trim tab could only be adjusted on the ground."
Jackson, Robert. "Technical Descriptions: Tail." Combat Legend Mitsubishi Zero, The Crowood Press Ltd, 2005, pp. 89.
Latest blog entry: 20cc A6M5 Zero Cowling Install
Help! Airfoils for V-Tail Tail Feathers Tahoed Sailplane Talk 4 Mar 05, 2017 12:16 AM
Discussion Converting slab tail feathers to built-up BernardW Balsa Builders 10 Nov 20, 2015 11:28 AM
Discussion Towards a Faster Blaster...what tail feathers? Nick61 Hand Launch 26 Oct 15, 2015 10:00 AM
