Jeti USA - 18 Channel Jeti Central Box 310 & 320 Power/Signal Distribution Systems
Introducing Brand New, 18 Channel Jeti Central Box 310 & 320 Power/Signal Distribution Systems with Built In Voltage Regulator w/Tx Adjustable Output (5V-8.4V) and Integrated Telemetry Expander.
Jeti USA Press Release!!!
The Jeti Central Box 320 is fully programmable switchboard with two (2) independent, stabilized power inputs with single voltage regulator (20A Continues/80A Peak) designed for complete power and signal management of servos with great emphasis on safety.
The Jeti Central Box 320 has a unique design that provides overload protection for up to 10 Standard (up to 415 oz/in, 30 kg/cm) and 8 Ultra Torque (up to 830 oz/in, 60 kg/cm) servos. The Jeti Central Box 320 features true Battery Redundancy, Ditex Servo Telemetry, Jeti EX Telemetry, and up to three (3) receiver inputs (2x 2.4GHz and 1x 900MHz) with serial (PPM, EX Bus) output for complete Power & RF Signal Redundancy. In addition the Jeti Central Box 320 has up to four (4) independent E1/E4 telemetry inputs. The onboard BEC allows the output voltage for the servo to be adjusted from 5V to 8.4V in 0.1V steps using Jeti Transmitter Device Explorer interface.
Learn More
Visit Esprit for all the info and models!
Oct 10, 2021, 02:32 PM
orthobird's Avatar
which should I purchase for a WARBIRD?
None of the servos are ganged up, meaning, one servo per surface max.
should i get the 310 or 320 for my application
thank you
CS
Oct 10, 2021, 04:54 PM
thank you
CS
Get the Jeti CB320, I always trying to keep my servos protected.
Also built in voltage regulator is very nice feature, simply 3S small packs feeds the system.
Zb/Esprit
Oct 16, 2021, 10:00 AM
Watts Up
Buck Tracker's Avatar
When are they arriving?
Dec 03, 2021, 08:05 PM
orthobird's Avatar
Any updates on when they will be arriving?
Dec 04, 2021, 09:52 AM
First shipment of Jeti CB310/320 is in USA, we are planning on shipping them out next week.
Zb/Esprit
News Jeti Central Box 210 Power Distribution Combo w/Magnetic Switch & R3/RSW Receivers Jim T. Radios 4 Oct 30, 2019 08:51 AM
News Jeti Central Box 100 Power Distribution Unit (Mini Dual Redundant System) Jim T. Radios 0 Oct 03, 2017 04:05 PM
Discussion Power distribution board for 6 volt system. Jim.Thompson Electric Power Systems 0 Nov 28, 2015 01:00 AM
Article Jeti Central Box 200 Power Distribution Unit w/Magnetic Switch Jason Cole Radios 1 Sep 04, 2013 09:40 AM
