AGFRC New - 74KG Powerful Torque IP67 Magnetic Waterproof and Dustproof Servo
AGFRC's new high performance digital waterproof superior servo...
AGFRC New Shape Design A81FHMW 74KG Powerful Torque IP67 Magnetic Waterproof and Dustproof Servo For Large RC Aircraft
Based on the advantages of A81FHM servo, A81FHMW adds IP67 magnetic waterproof function, and the waterproof depth can be as high as 1 meter. It can reliably accompany you in rainy days, muddy roads, streams, snow and other environments. The internal structure is upgraded with a high-efficiency four-poles brushless motor, ultra-sturdy steel gears, and dust-proof metal bearings, which not only improve the product's tightness and crash resistance, but also effectively prevent sand and dust. Believe that the super torque of 74KG can bring crazy extreme challenges to your model.
Features
  • High Performance Digital Waterproof Superior Servo
  • Long Lifespan 4-Poles Brushless Motor
  • Dust Resistant And Splash Proof Metal Four Bearings
  • Magnetic Sensor Waterproof IP67
  • 2S Lipo High Voltage Compatible
  • Extremely Strong Steel Gears
  • Programmable digital circuit
  • Environmentally Friendly Materials
  • Ideal For 1/8 1/10 On-Road, Buggy, Monster Truck, Racing Car, Large Size Plane, Helicopter, UAV, Robot, Robotic Arm And Engine Etc.
Specification - Iterm name: A81FHMW
  • Operating Voltage: 4.8-8.4V
  • Operating speed: 0.190sec/60 @ 4.8V
  • Operating speed: 0.165sec/60 @ 6.0V
  • Operating speed: 0.135sec/60 @ 7.4V
  • Operating speed: 0.125sec/60 @ 8.4V
  • Stall Torque: 45 kg-cm (625 oz-in) @ 4.8V
  • Stall Torque: 55 kg-cm (764 oz-in) @ 6.0V
  • Stall Torque: 65 kg-cm (903 oz-in) @ 7.4V
  • Stall Torque: 74 kg-cm (1028 oz-in) @ 8.4V
  • Gear: Steel
  • Motor: 4-Poles Brushless Motor
  • Size: 40*20*38mm (1.57 x 0.78 x 1.5 in)
  • Weight: 85g
  • Connector Wire: TYU 300 mm / 22AWG
For More Info
CLICK HERE
Oct 07, 2021, 06:56 AM
what's the real performance gain with 4-poles motor ?
Oct 07, 2021, 10:02 PM
The 4-pole motor can bear much higher torque than 2-pole motor in same size, which can meet the requirement for the application request large torque but limit space.
Oct 07, 2021, 10:33 PM
what about servos with more torque than yours that don't use 4-pole motors ?
https://futabausa.com/product/hps-a700/
Oct 09, 2021, 12:49 AM
4 pole gives quicker zero starts and direction reversal.
Its like being in a lower gear.
Oct 09, 2021, 03:51 AM
That is the 4-pole motor, even it does not mark it.
Oct 10, 2021, 09:05 AM
Radikal's Avatar
How much quicker ?
Oct 10, 2021, 09:55 AM
Originally Posted by Radikal
How much quicker ?
The percentage would depend on a few variables, like armature mass, driven load and pwm frequency, but in general a two pole motor has wider dead zone between poles reducing the torque at certain points in each rotation. A four pole motor has much narrower inter pole dead zones relative to each rotation so for a given mass (and load) it can achieve faster armature transition with more constant torque as a result. That is why it is more pronounced at zero up or in start transitions across zero (reversing) where inertia doesn't help. Constant and startup torque is always higher with four, it's a key reason I/C starter motors are always four pole.
If I had one of these to compare to a two pole equivalent, it would be done with my usual technique, measuring under various loads with a laser and high speed camera. It always reveals all, especially stopping, and braking to reverse at fast PWM transitions.
Oct 10, 2021, 12:11 PM
send these servos to Tareq I want to see if they outperform and will last any longer than MKS servos
everything else is pure marketing and bla bla bla...
''Ideal For 1/8 1/10 On-Road, Buggy, Monster Truck, Racing Car, Large Size Plane, Helicopter, UAV, Robot, Robotic Arm And Engine Etc.''
Tareq Alsaadi 3DX Russia 2017 Goblin Black Thunder with KD lipo batteries gold edition (4 min 44 sec)
Jan 02, 2022, 05:17 PM
kenstick's Avatar
Now they need to be helical gears. Just would be icing on the cake.
I like AGF I have many of them and are programmable.
I am thinking these for my new 140 bushmaster
Jan 03, 2022, 10:26 AM
do you have or recommend any of the low profile series for aircraft ?
Jan 05, 2022, 05:38 PM
kenstick's Avatar
I don't have any low profile but they do have a lot of them.
https://www.agf-rc.com/full-plastic-...-servo-c70762/
New Product New Arrival! AGFRC 12V 66KG Monster Torque Programmable IP67 Waterproof Servo Eric Zhu Off-Road Vehicles 1 Jun 04, 2020 04:52 AM
