New Futaba S AG-300 F3K Servo
Futaba really took the time to think about how to pack the best performance into a servo specifically made for DLGs.
New Servo for DLG's
Got this from Futaba about a new servo for F3K planes.
Futaba really took the time to think about how to pack the best performance into a servo specifically made for DLGs. The result is the S AG-300. This servo has an all aluminum case with a metal output gear. The S AG-300 servo is also fully programmable like most Futaba SBUS servos and it includes mounting tabs for mounting the servo in the horizontal position which is perfect for the nose of DLG Gliders. Price is listed at $79.99.
Features:
  • For Glider/ F3K
  • Programmable/HV Coreless Servo.
  • Programmable and compatible with S.Bus and S.Bus2 systems.
  • Can be connected to a PC using the CIU-2/-3 USB adapter sold separately.
  • Metal Final Gear
  • Upper/middle/bottom: Aluminum Case
Specifications:
  • Speed: 0.130 sec/60°at 3.8V / 0.065 sec/60° at 7.4V
  • Torque: 1.5 kgf/cm at 3.8V / 20.8 ozf/in at 3.8V / 2.5 kgf/cm at 7.4V / 34.7 ozf/in at 7.4V
  • Size: 23.5 mm x 8.0 mm x 19.7 mm (0.93 in x 0.32 in x 0.78 in)
  • Weight: 10.8g (0.38 oz)
  • Rated Voltage: 4.8V-7.4V
  • Operating Voltage: 3.8-8.4V
Check out the New Futaba S AG-300 F3K Servo Here
Oct 05, 2021, 05:13 PM
RV7guy
dnbarrie11's Avatar
Got some
I have several of these servos and will be using them on a F5J plane soon. I'll use them on ailerons. They are strong and light with good numbers.
Futaba should be coming out with a vertical mounted version too.
Darwin N. Barrie
Chandler, AZ
Team Futaba
Oct 05, 2021, 06:32 PM
Only 80.00? Is there another configuration other than horizontal?
Oct 05, 2021, 07:17 PM
mgallian's Avatar
Makes MKS look more appealing! Futaba is always very proud of their stuff/pricing.
Oct 05, 2021, 07:34 PM
Sensoar's Avatar
Is that in Pesos or Lira...
Oct 05, 2021, 08:10 PM
iVoid Warranties
flyinghedgehogs's Avatar
Hopefully HKD
Metal Final Gear
...what are the other gears made of? I would rather have my servo break in an observable fashion than just cease functioning due to a stripped internal gear. Given that you can get a servo for $9.00 that has the entire gear train made of medal, why does the $80.00 servo not have that?
I would think the FrSky Xact HV5612 servo in this size range would be a better value, with comparable programming and telemetry options.
Oct 13, 2021, 04:39 PM
hawkagner
Hitec servos x Futaba servos
Unfortunately we have to support the US Futaba's big shots. Hitec makes a hell of good servos, like the HS 645 MG and will cost you around the reasonable $ 30.00 bucks
Oct 14, 2021, 01:57 AM
No risk, no fun
Siggy101's Avatar
Amazing looking servos.
Great to see another F3K focused servo.
80 bucks.... GOODBYE!
Come on Futaba, do you think we were born yesterday?
Discussion Futaba's New Line of Standard Servos carlcorn Servos 2 Apr 23, 2021 08:24 PM
Alert New York AG seeks to depose Eric Trump in investigation of Trump's finances Broken Wings Life, The Universe, and Politics 7 Aug 25, 2020 07:08 AM
New Product New Blue Bird BMS-A10 F3K Servos ak79 Hand Launch 133 Jan 09, 2018 11:13 PM
Discussion PA's AG In Trouble WingNut64 Life, The Universe, and Politics 2 Sep 21, 2015 05:25 PM
Discussion new f3k Window sticker(s) and USA F3K Team STICKER dougmontgomery Hand Launch 39 Oct 31, 2012 07:28 PM
