Jul 28, 2005, 07:27 AM
Pull-Pull method vs regular method for foamis
pros and cons both methods for foami plane 3D flight.
Jul 28, 2005, 01:41 PM
Off playing tug
ChrisBowker's Avatar
pull pull is good becasue the servo is always pulling, it works very good for elevator and rudder, i would not recomend running it on the ailerons. its also nice and lite.
Jul 28, 2005, 03:13 PM
I'm not a fan of pull-pull control lines on foamies. I've tried it a couple times on my 3DFoamy planes. The problem is that the control lines must be pulled tight, and the foam simply isn't ridged enough to support it. I'm not saying it can't be done... just, I haven't figured out how to do it without mashing foam. Also, I haven't flown a foamie yet that really neeed a pull-pull rudder. In my limited experience, as long as the control rod is ridged enough, which is really easy to do just by gluing the control rod sleeve to the fuselage, you can make a push-pull rudder work just as well as a pull-pull.
-- Brian
Discussion What's your favorite line for rigging Pull-Pull..... Mr. Wiz Sport Planes 26 May 01, 2016 12:40 PM
Idea Simple Method Of Fixing Pull-Pull Thread To Servo Arm Mister UHU Indoor Pattern/F3P 9 Jan 24, 2007 12:08 PM
Question Best fishing line for pull-pull systems? PfalzPflyer Scale Kit/Scratch Built 17 Aug 26, 2005 07:40 AM
Question Best fishing line for pull-pull systems? PfalzPflyer Scratchbuilt Indoor and Micro Models 4 Aug 26, 2005 12:38 AM
neat solution for pull/pull tension. maux 3D Flying 6 Aug 13, 2005 05:17 PM
