What the Heck Wednesday - Flying Wing Spin of Death
This week on What the Heck Wednesday we have another video from Xjet and these guys are some of my favorites.
This week on What the Heck Wednesday we have another video from Xjet and these guys are some of my favorites. They are always entertaining and certainly an example of a club that knows how to have a good time at the flying field. It's a long video, but the crash we are highlighting happens right at the very beginning. The pilot climbs while doing some aerobatics and then cuts the power while pulling back into a loop. That's when it gets hairy and the recovery turns into an uncontrolled spin all the way into the ground.
What could he have done differently to save it and prevent the crash?
If you have a video of a weird or entertaining crash and would like to be featured on What the Heck Wednesday, please send me a PM with your submission.
Who STOL that RC plane? (34 min 56 sec)
Sep 23, 2021, 06:38 AM
Pity...
With a slightly conservative CG, all he'd need to have done was to shut throttle and let go of the sticks for a bit and it would have recovered on its own.
If his CG was aggressively aft, he didn't stand much of a chance in any event (he did say he tried to recover).
Sep 23, 2021, 10:24 AM
Balsadustus Producerus
Yeah, he was holding full up the whole time. You'd think that would make it recover.
Latest blog entry: Single Channel Case
Sep 23, 2021, 02:07 PM
Without a tail, one does not have the control authority to effectively recover from spins. One might get lucky and pull out after the spin changes to a spiral dive. This is assuming the plane has enough yaw-stability built into it. I would do aerobatics with a Zagi or plane with a tail.
Sep 28, 2021, 10:00 PM
Heath
"What could he have done differently to save it and prevent the crash?"
  1. Stop pulling back on the elevator.
  2. Push the nose down.
  3. Counter the rotation with right aileron.
  4. Pull back on the elevator to return to level flight.
He pulled back on the elevator all the way into the ground ensuring the plane never stop stalling.
Stall recovery is something you have to practice. Pushing the nose at the ground can be scary at first but with some flying wings it is the best way to get them out of a stall.
Nothing lucky about it. Pushing the nose down forces the plane into a spiral dive. Recover from the spiral dive by first stopping the rotation using ailerons then pulling out like any other dive. Spins and stalls with a flying wing are great fun as long as you have a little altitude.
Sep 30, 2021, 06:56 PM
Also know as delta death spiral. Most deltas cannot recover. Given enough height I can recover from one with my Assassin, but it requires max throws to do so.
Oct 01, 2021, 12:57 AM
It shouldn't take more than a couple of turns to recover. You may be flying with a CG that is too aft. Also, if you're flying without winglets you might consider adding small winglets to make yaw stability better.
I've found that nose down stick till both wings are flying and then gentle roll-out of the spiral dive will work with almost any flying wing that has a reasonable CG.
Just because it flew up until the spin, does not necessarily mean the CG is reasonable.
Oct 01, 2021, 11:49 PM
I never understood this comment. I fly the cg where I want it, moving cg just to get out of a flat spin is not something I would not even consider. Not going to add winglets either. Dealing with the death spirals is not a problem for me.
Oct 02, 2021, 12:00 PM
Umm, yeah, obviously you'll fly your plane any way you want to. And obviously you personally may know how to get your specific Assassin plane out of the spin - you said that clearly in your post.
I was simply imparting some insight about how to set up the airplane (yours and others) to help avoid spins in the first place and enable easier recovery if a spin does occur - not just for you and your particular case/airplane, but for other people who may be interested as well. After all, the thread is about spins.
How moving the CG forward helps in that respect is a discussion in its own right and is discussed at length in other posts (for anyone who may be interested). And of course it is a trade-off, as always.
Oct 12, 2021, 07:54 AM
The runway used to be longer
Mad_Mike's Avatar
If you go to 24:45 in the video you can see a passable landing.
Surprising for this crew.
Article What the Heck Wednesday - I Don't Even Know What to Call This! Jason Cole General RC Discussion 25 Aug 09, 2021 10:58 AM
Article What the Heck Wednesday - RC Gas Trainer Crash Jason Cole Fuel Plane Talk 60 May 23, 2021 08:31 AM
Article What the Heck Wednesday - Flying Wing Crash and Go?!? Jason Cole Flying Wings 12 Nov 11, 2020 05:36 PM
Article What the Heck Wednesday - RC Helicopter Crash Jason Cole Electric Heli Talk 26 Sep 15, 2020 09:43 AM
Article What the Heck Wednesday - RC Jet Crash Jason Cole Fuel Jet Talk 31 Sep 13, 2020 06:26 PM
