Sep 20, 2021, 04:11 PM
Dantiel's Avatar
Crescent EDF nurflügel
hello folks,
There I share an experimental nurflügel prototype i just finished making. It consists of a 1,3mm CF rod and Skytex Membrane therefore being very light and aerolastic. I think this shape may have interesting aerodynamic implications. Maidenflight soon
Sep 21, 2021, 05:31 PM
Dantiel's Avatar
Crescent EDF flying wing TestFlight 21.09.21
Crescent EDF flying wing TestFlight 21.09.21 (0 min 42 sec)
Control by wing morphing is still insufficient and responding too slow. Flight performance seems ok.
Wingspan: 472mm
motor: 30mm EDF
control: 2x EMAX 9051
lipo: 2S 180mah
weight: 60g
do you have ideas for improvement of control ?
Sep 23, 2021, 01:25 AM
Originally Posted by Dantiel
hello folks,
be interested.
The moon and flexible morphing wings are innovative.
Sep 23, 2021, 07:27 AM
Dantiel's Avatar
Originally Posted by y.takahashi
be interested.
thank you. but i must find how control can be improved, maybe requires stronger servos.. another consideration is to use two EDF on the outer "arms" of the crescent
Sep 23, 2021, 07:27 PM
Fly me to the moon...
Atom1025's Avatar
Very cool. I build most of my rc planes with cf rod and fabric.
Definitely like the look if this.
Oct 01, 2021, 03:02 PM
B for Bruce
BMatthews's Avatar
It looks to be suffering from the lack of any vertical tail. For giggles you might try adding one or two vertical surfaces that are well behind the CG and see if that stops some of the more radical yawing diversions. If it does help then work at reducing the size to see how little you can get away with while still helping out.
A VERY cool and innovative concept though. And being so innovative you're certainly in the right sub forum! I'm looking forward to more results.
Oct 08, 2021, 08:57 PM
Dantiel's Avatar
@BMatthews theres no YAW instability in this plane, because EDF unit is much at front, and the "wingtips/winglets" are so much aft that a vertical tail is not needed
i tried today move battery more behind which gave more elevon authority and had few more sustained flied, i start to feel this shape may have interesting abilities . but in general the plane is behaving very sluggish especially at higher speed control is almost unresponsive and membrane easily starts to flutter.
at the moment i see different options to improve this. either use another CF ring to stop flutter and also cause better response to control input... the other idea is to rebuild the plane by using EPP, which is in general a better match to an EDF unit... but i dont know how wing morphing can work on 3mm EPP..
also i envision another version of this with an EDF unit on each side, fused into the wing, for differential thrust at its best
Oct 19, 2021, 02:03 AM
Cool airplane!
I'm not sure what you call that clearly spinning out of control at 00:30 in the video, but that is usually called severe yaw instability by most. The fact that it only sometimes happen (likely when at higher AOA) does not mean you don't have yaw instability problems.
Now, it's true that vertical fin(s) are just one way to solve it, but that would certainly be the most straightforward way to solve it.
To deal with the spinning issue, you could have computer-controlled spit flaps (like on the B2 bomber) or computer-controlled differential trust using twin motor design, but of course those are a lot more effort. For those options I say computer-controlled because there's almost no one capable of having the reflexes necessary to control those options manually...
Video Virtuoso of Thrust: Dual EDF Thrust Vectoring VTOL System MONOPHAN1 VTOLs 40 Oct 16, 2021 08:29 PM
Discussion Hadron and Thrust Vectoring rwilabee Flying Wings 0 Sep 15, 2015 04:44 PM
Help! Thrust measurement- Thrust Vectoring vineethoffline Modeling Science 6 May 15, 2013 12:42 PM
Discussion My Twinjet with Thrust Vectoring and Thrust Diff. Pitchspeeder Pusher Prop Jet Models 25 Nov 13, 2007 08:10 PM
Video Twinjet with Thrust Vectoring and Thrust Diff. Pitchspeeder Electric Plane Talk 1 Jul 17, 2007 09:45 PM
