Sep 15, 2021, 03:05 AM
9n6p yyy
Good afternoon, a friend asked to rewind the motor for the boat (Skorpion 22 16, 9N6P) was reeled
Classical circuit AБВ AБВ AБВ
I want to try AБВ / AБВ / AБВ (YYY)
Tell me how to connect the leads of the coils correctly.
Or tell me which circuit is better to use for this motor configuration
Thank you in advance.
Sep 15, 2021, 06:58 AM
Fourdan's Avatar
Hi
I think you are speaking of a Scorpion HKII 2216-xxx
Yes it is a 9N6P
YYY (all three phases in parallel) is a config providing a high Kv
The original is D (all in serial , delta connecting)
if 12 turns Kv = 3350 rpm/V
* the first way to get your desired Kv is to change the number of turns, keeping D (all serial) connecting
You can use the freeware "turn calculator"
What is your desired Kv (rpm/V)
Louis
Latest blog entry: Scorpion Calc
Sep 15, 2021, 07:54 AM
Originally Posted by Fourdan
Hi
Yes it is a 9N6P
Louis
Thank you so much for your prompt response, yes, the Scorpion HKII 2216-12 motor, but already rewound by someone.
It is not possible to measure KV, the winding is destroyed, I counted 7 turns by heart, comrade claims
Before the breakdown, the KV was 3400.
I need to reel 2850 - 3000 kv
You will have to make a test winding with a thin wire.
I will try D and YYY, measure the resistance, and then decide which circuit to use.
Only I don't know how to connect the end of the coils at YYY, if it's not difficult, please tell me
Information from the manufacturer
Specifications [HK-2216-12]
Stator Diameter 22.0 mm (0.87 in)
Stator Thickness 16.0 mm (0.63 in)
No. of Stator Arms 9
Magnet Poles 6
Motor Wind 12 Turn Delta
Motor Wire 12-Strand 0.21mm
Motor Kv 3350 RPM / Volt
It turns out 12 turns per slot.
With D 7 turns per slot, KV should be 5742
It turns out for D, KV about 2850 you need 14 turns per slot.
Most likely YYY has many turns and the wire will turn out to be very thin, you need to use the original D
Sep 15, 2021, 08:40 AM
Fourdan's Avatar
Magnet Poles 6
Hi MSER
If you want Kv around 2900 rpm/V
Try to stay D
Number of turns = 12 x 3350 / 2900 = rounded to 14 you are right
wire try first (temporary coil) a diam to fill the slot at maximum with 14 turns
for info about YYY
First connect three coils "A" (or B or C) in // , respect A_in ; A_out
... then connect in star
Louis
Sep 15, 2021, 10:22 AM
Hi MSER
Try to stay D
for info about YYY
Louis
Thank you, I'm starting to wind the test winding D, 14 turns
Sep 17, 2021, 01:30 AM
Hi MSER
Try to stay D
for info about YYY
Louis
I made a test winding D of 14 turns per tooth, got a strange result KV 1722 (emeter switched to 6 magnets)
It turns out that I uncoiled the motor and 7 turns were wound on the tooth (I counted carefully), the friend said that before the KV winding broke, it was 3400.
It turns out 7 * 3400/14 = 1700
What I got when winding D 14 turns.
For KV 2850 - 3000 8 turns must be wound.
From all of the above, one thing is not clear, the factory winding of this motor is 12 turns per tooth and KV = 3350, the numbers in my head do not converge.
And I still did not understand the connection diagram YYY (First, connect three coils "A" (or B or C) to //, observe A_in; A_out
... then connect to the star)
If possible more information ...
Thanks.
Sep 17, 2021, 03:46 AM
Fourdan's Avatar
Thanks.
Hi MSER
Maybe for Scorpion stock HK 2216 the windings are 12 conductors per slot (6 turns per turn) ?
I have never dismantled one
About YYY
Very easy to understand
Consider 3 coils "A" there are 6 ends A_1_in, A_1_out, A_2_in, A_2_out, A_3_in, A_3_out
paralleling means :
connect // A_1_in, A_2_in, A_3_in --> A_in
connect // A_1_out, A_2_out, A_3_out --> A_out
same for 6 ends B and 6 ends C leading to B_in, B_out and C_in, C_out
Then connect Y the 6 //ends
pigtail = A_out, B_out, C_out (or all _in)
Louis
Sep 17, 2021, 05:49 AM
Hi MSER
About YYY
paralleling means :
Louis
Thank you so much, I will try.
I will let you know the result.
Sep 17, 2021, 11:50 AM
Wound D, 8 turns, per tooth, wire diameter 0.75mm
V = 10.93
A = 1.6
PRM = 31720
Wt = 17
kv = 2902
Ω = 0.040
Thanks for the help
Sep 17, 2021, 12:04 PM
Fourdan's Avatar
V = 10.93
A = 1.6
PRM = 31720
Wt = 17
KV = 2902
mΩ = 0.040
Thanks for the help
Hi
I suppose it is Rm = 0.040 ohm (40 milliohm)
Louis
Sep 18, 2021, 04:05 AM
Hi
Louis
Good afternoon yeah
Rm = 0,040 Ом (40 milliohm)
I would like to have less winding resistance.
It remains to balance the rotor and put it on the boat
Sep 21, 2021, 12:54 PM
powercroco's Avatar
http://powerditto.de/scorpion/9N6P2221scorpion.html
winded with 0,8mm wire.
Discussion yyy ARUP Scale Sailplanes 95 Sep 09, 2014 06:56 PM
Discussion yyy unclecrash Test Forum 0 Oct 27, 2013 01:59 PM
Discussion Scorpion 3026 9N6P rewind for ChangeSun 90mm 12Blade EDF unit modisc Electric Ducted Fan Jet Talk 0 Jan 01, 2012 07:36 PM
Help! Parallel Connection 9N6P (help) GRANATO Electric Motor Design and Construction 19 Sep 25, 2010 09:59 PM
Guess the XXX and YYY GWFAMI Life, The Universe, and Politics 13 Oct 02, 2009 11:48 AM
